4-434 four-thread multi-function overlock machine
Open up the front cover. There should be a diagram right there, and you want to thread your serger step-by-step per the color-coded diagram so that the needle is in time with the movement of the loopers. If you randomly go about threading it instead of in sequence, the threads will collide and you will create a jam. The usual threading order: Upper Looper, Lower Looper, Left Needle, then Right Needle. Do you have long serger tweezers? Do you have a Looper Threader? If not, these are great tools to assist you as the Lower Looper is threaded right to left- an eye all the way to the far left, so it helps to have the tweezers and Looper Threader to maneuver in this very tight area. Many new serger users don't realize that other eye is "hiding" and miss threading it! Hopefully, you have a manual with additional pictures to help guide you. If you need a manual, try allsewingparts.com and perhaps they have one specific to your serger. Note: When you insert your needles (make sure they are #11 and #14 specific for your particular machine), the left needle will be the same size as right needle, but will APPEAR higher once both are pushed up into each of their respective needle shafts. Note: Hold onto needles or put a piece of fabric under the area when changing them/replacing them because they can easily fall out causing damage to your machine. Hope this helps. Jimmy
SOURCE: Threading three thread Baby Lock Overlocker EF 405
Ther should be a color coded threading chart on the front inside cover.
SOURCE: threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
SOURCE: I need instructions to Thread a White Super Lock 534 Serger
I hope this helps. there a lot of other vidios you can try as well. DFD
SOURCE: Threading an Empisal Overlocker - Model S4D
All sergers thread the same way and sergers have to be threaded in a certain order. I made a jingle out of it...
upper looper
lower looper
right needle
left
It would be best to have a tweezers handy to help with the thread and threading.
always be sure the lower looper thread goes over the top of the upper looper then out the back. I would be surprised if your thread guides are not color coded.
If you look at the top thread guides or the spools. First from left to right thread the 3rd spool, then the fourth spool. Then you thread the right needle (the second spool) then the left needle (1st spool.
The lower looper can be tricky because you have to thread it from the back of the looper to the front.
Pull the threads out the back from under the foot. Then go ahead and run it slow watching to see if it starts making a chain. It should. If not do it over again.
Good luck
Rick Engel
SOURCE: Need instruction on threading of janome ezy lock 604D overlocker.
www.janomestuff.com answer it all
what type of needles does it use?
