I'm sorry to hear your DC24 Animal isn't picking up as well as usual. Although I note you've already checked for blockages, it sounds as though this is likely to be the cause of the issue.
To locate and remove any blockages, please follow the steps shown in our online Support guide:
http://support.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
In normal use, the filters should be washed at least once a month, as shown in the video below. Use cold water without detergent, and allow the filters to dry somewhere warm for at least 24 hours before replacing them in the machine.
I'm confident this will resolve the issue, but if you'd like any further assistance or advice, please give us a call on 0800 298 0298 (UK), or 1-866-693-9766.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com/
SOURCE: Dyson Animal clogged
Here is the best way to clean your dyson that I have found!
http://www.crazysquirrel.com/diy/dyson/cylinder-clean-page-1.jspx
SOURCE: Dyson Animal-suction loss
Had the same problem twice and washed the filter to no avail. Called Dyson to troubleshoot, and in one minute they had me removing the purple plastic noodle shaped piece towards the bottom on the side (the next time it was the silver noodle on the opposite side). Inside was a bent pen and tons of debris wrapped around it that slowed the suction. Poked the debris out, and it worked perfectly.
SOURCE: no suction on dyson dc24 ball
Well i just fixed my Dyson Ball with the same problem you have. My wife and i found out it was a crumpled receipt in the lower section of the hose at the upright/handheld pivot #3 in diagram and it was catching cat hair and other things. I began by removing the canister and turned on the vacuum to see if the direct access to the fan had suction. Then i moved to #5; i reattached the canister and threw in some cat hair into it from the bottom. i turned on the vaccum to see if it spinned around; it didnt. I then moved to #4, i removed the head and then turned on the vaccum to see if maybe the head had a leak at the top connecter; as i predicted the strength was minimal. I then worked my way to #1 to see if the strength was the same or if there was a difference. no difference for us. Well then it must be #3.. of course the last one i checked. I used a small flashlight and peared in and i didnt see anything... i then used a coathanger very softly as to not puncture the hose. i then noticed some hair being pushed out but the main culprit wasnt showing. my wife gave me needle nose pliers and i pried the hose off of the top connection in #3; so i could get a better look; you may be able to push it off with your hands. and viola! a crumpled reciept for 3 Monster energy drinks.... the same ones....i drink... oops!... hopes this helps. just go through it step by step. youll know its working once stuff begins to spin in the canister. almost regretted throwing that dyson registry junk away.
SOURCE: dyson dc07 animal\ no suction
There could be a few things that would cause your Dyson to have no suction. I will give
you detailed step by step instructions along with pictures on how you can
diagnose this.
Possible Problem
#1. The first problem is extremely common. In fact, we probably see
between 2-3 of these problems every week. It mostly happens after people
take the bottom plate off the vacuum in order to clean the roller brush. What happens
is when they reinstall the bottom plate, they put it on on
incorrectly. It's actually very easy to do. When the bottom plate
(soleplate) is installed wrong, there will be a gap between the bottom plate,
and the agitator housing, or the purple tray the roller brush sits in. This will cause the
soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to
the user that vacuum has lost suction power because without the brushes hitting
the carpet, the machine will not pick up very well on floors, but when they use the
attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in
between the two housings:
Here's another picture, that is the RIGHT way to install
the soleplate:
I would say probably 6 times
out of 10 this is the problem with the customers machine. If you checked the
soleplate and it is installed correctly, move on to the second possible
problem.
Possible Problem # 2. Turn the
vacuum cleaner upside down so the brush roller is facing upwards. I found the
easiest way to work on it is to put it on a counter top or work bench. On the
left hand side behind the roller brush you should see a flexible transparent
hose that goes from the motor to the agitator housing. This hose actually
has a lot of strain on it when the vacuum cleaner is in the reclined position.
When the first few series of Dyson DC07 models came out, they didn't make this
hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually
right where the end of the hose that goes into the agitator housing. Examine your
hose and see if you have any visible cracks in this hose. If you need to you may
just remove the entire hose assembly by pulling on it. It will easily come right
out of the machine so you can inspect it better. Here's a picture of where the hose
usually cracks:
This would
also explain why the vacuum works fine when using the attachments, but not on
the floors. The attachment hose uses a different suction channel, and when the
machine is in the upright position, no suction goes through this hose. If you do
find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part #
904219
Possible Problem #3.
I would suspect that this may not be the problem, but if neither of the
solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added
there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction
port covers at both of these locations:
Possible Problem #4. If none of the above solutions worked for
you, try this last one. The Dyson DC07
models use a clutch mechanism that stops the roller brush from spinning when
changed from carpet mode to bare floor mode. This clutch mechanism is a notorious
problem with all Dyson models, in fact they were such a problem that Dyson
had to redesign the DC07 model to a non-clutch system. Even if yours is one of
the newer ones that don't use a clutch, yours still has a belt inside. You can
tell if your model uses a clutch or not by the shape of the roller brush. If
your brush is a perfect cylinder shape, yours does NOT have a clutch. To check
and see if the clutch or the belt have gone bad, first release the handle on the
vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet
mode. Now while the handle has been released, turn the machine upside down and
see if the brushes are spinning. If the brushes are spinning then turn the
vacuum right side up and put the brushes on the floor. Can you still hear the
brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your
brush roll, clutch, or belt have gone bad.
If these solutions still didn't fix your problem, I'd be happy to try and help you further. Just use the Clarification Request, or comment section here on the Fixya repair page.
If this repair was helpful to
you, please be sure to rate this repair as helpful by clicking the thumbs up
icons in the top right hand corner of the repair. Thanks so much!
Chris J.
GoVacuum
SOURCE: dyson ball dc24 the brush bar is not turning
Hi its Darran at Dyson.
With the machine switched off, press the re-set switch on the side of the head, making sure you push the button in as far as you can. When you switch the machine back on and lower it into the vacuuming position, the brush bar should start turning.
If this doesn't rsolve the problem, please contact our Helpline on 0800 298 0298, between the hours of 7am - 10pm, 7 days a week.
Kind regards
Darran
Dyson Customer Service
