The removeable door shelves (containers) are partly molded white plastic and partly clear plastic (in the front). How can we separate the clear plastic part from the white plastic part? There appears to be moisture and possibly mold inside the clear plastic and we need to remove it in order to clean inside it. Thank you.
SOURCE: How do I put a door seal gasket back on my LG front loader?
If it is apparently just too tight to go back on, then a good place to start is petroleum jelly (vaseline) on the drum where you are trying to fit the gasket to help ease it on. The other possible solition is to remove the gasket completely, soak ot in very hot water for a few minutes and then try to fit the difficul part of the gasket you are struggling with first, then fiot the other end
SOURCE: There is mold on the underside of the door ring.
It cannot be cleaned - it must be replaced.
The rubber absorbs the mold - and you cannot get rid of the smell.
This part is called a door bellow.
It will require disassembly of the machine to replace - and a professional service contractor is recommended.
Thanks for using Fixya - a 4 THUMBS rating is appreciated for answering your FREE question.
Testimonial: "Very quick response. Professional advice and approach. Provided terminology to approach expert with. Thank you"
SOURCE: clothes stained and mold growing on rubber ring
Use a mixture of bleach and water in a spray bottle to kill the mold. Leave door open after washing. Also spray your drum and rinse unloaded to kill the mold on the inner drum.
SOURCE: LG-P197WVS: Hose from under frezeer door to water
ck with REPAIRCLINIC.com. repair help & parts
SOURCE: washer smells bad - musty
smell are normally due to 3 culprits
low temp wash , liquid soap , moisture
affresh washer cleaner may be worth a try
video
