Re: I need a door shelf for my Frigidaire side by side...
You did not list freezer door or refrigerator so I will link you to all of them and you can choose the one you need. These are all for Frigidaire FRS3R5EMB
It is a little known make with no published maker and seems to be bold only by 'The Brick' in Canada where I am! Use Superglue and Duct Tape until you buy a new one. There are very few spares apart from one Door Shelf Bin here. Is this it?
This is usually caused by a clogged drain hose. Blow air thru it from the back to clear the clog. Good luck, hope this helps. Also make sure door seals are good and doors are closing properly.
If the icemaker was removed and reinstalled, double check to make sure the plug is fully engaged and the ice bin shut off arm is back to the down position.
I understand the freezer on your Frigidaire refrigerator, model# FRS3R5EMB, will not make ice or keep anything frozen in the summer months. First, I suggest lowering the temperature in your freezer and allowing 24 hours for the temperature to stabilize. Secondly, check the seal around the door to make sure it has not been compromised in any way. Lastly make sure that you are not opening the freezer door frequently or leaving it open for long periods of time. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
Sounds like your door or doors are being held open by an object inside. This is causing the cooling system to run constantly and thus freezing items in the fridge. Check that the shelf under the ice drawer is overpacked. the dispenser runs inro things on the shelf right under that storage compartment occasionally on my fridge. Hope that helps.
since on differnet models it goes right or left,
but you should be able to push the shelf one way, enough so that the other side pops out of the wall
then slide in the long side first, you will see what i mean when you have the shelf out
push the long side in with a lil pressure and raise the shelf the leve you want it installed on
