WON'T BOOT UP
SOURCE: I need to reset the ram on a hp pavillion slimline but the cd tra
Just unscrew, remove the entire CD ROM, fix the RAM properly and while connecting the CD ROM ensure that all connections are snug tight...sodeep
SOURCE: HP Slimline Pavillion s3123w monitor going to sleep.
Sounds like the motherboard might be bad but go thru these steps.
Unseat and reseat the memory one stick at a time in each slot one at at time and turn on the computer after each stick reinsertion.
If that doesn't get the video to come back up then go ahead and unseat and reseat the CPU. Then try turning on the computer.
If that doesn't do it, make sure there is no power going to the hard drive or the dvd drive. Then try turning on the computer.
If you do all of these steps and you still have no video, then the motherboard is bad and would need to be replaced.
SOURCE: I have done a factory
Hmmmm... nice detailed desktop!
But u failed to mentin ur MONiTOR?
Wut is it? CRT, LCD, monochrome?
SOURCE: Slimline s3123w won't boot.
If you get no video display at all, the BIOS most likely has failed. The motherboard can only be obtained from HP. The power connector is smaller than normal. I hope that you can get some video and then you could remove the battery for a minute or replace it and see if you can get to the BIOS setup.
