Kitchen Ranges Logo
Anonymous Posted on Jan 22, 2012
Kenmore Electric Range Model #911 9237313-All burners quit at once?
Older model Kenmore Electric Range - all burners stopped heating at about the same time. How to fix?
  • Anonymous Jan 22, 2012
    Checked the fuse box...nothing was off but I did reset the marked Range. Tried the stove again but burners still don't work. The over DOES work though???
    Opps...typing too fast...I reset the one marked 'Range'. Top burners still don't work. The oven DOES work though???
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Jan 22, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
2314
Points
24
Have you checked your fuse box. The Electric Range is on a separate circuit. Check to see if it is tripped or off.
If it has tripped and you reset it, that usually means there is a problem with the electric range.
Let me know if that helps.
Testimonial: "This did not fix the problem but easily could have been the reason my burners wouldn't work. I appreciate the suggestion."
5 Related Answers
Anonymous
  • 1214 Answers
  • Posted on Jan 30, 2009
SOURCE: need manual for Kenmore Range
You can download one for free at www.managemyhome.com
Anonymous
  • 6784 Answers
  • Posted on Apr 21, 2009
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Anonymous
  • 1865 Answers
  • Posted on Jun 10, 2009
SOURCE: Kenmore 790.9622 electric range - front right
You have to use a voltmeter to make sure the element is getting voltage, if it is, then replace the element
heavyt15
heavyt15
  • 91 Answers
  • Posted on Aug 18, 2009
SOURCE: Kenmore range front left BIG burner will not work
Check infinite switch...110V one side 11ov other side
Anonymous
  • Posted on Mar 11, 2010
SOURCE: Kenmore drop-in electric range plug melted
Manual for 6284588450
Kenmore Gas Range Model 790.7851 - top burners have gradually stopped working over last 6 months, appears to be low flow of gas but did not occur all at once, happened at each burner one at a time. Now...
you will notice small holes around your burner. Look at the burners holes next to your spark igniter. A paper clip will fit perfectly into the small hole to clean them. This is very common, boil overs clog these holes with debris and does not allow gas flow to ignite properly.
http://www.on-timeappliance.com
I have a kenmore ceramic top electric stove and one of the burners quit getting hot. what could be the problem
It is a kenmore glass top stove about18 years old. One of the burners stop working just wondering if I can fix it myself?
Kenmore model number 91193412000 burners went out
Its almost impossible to tell you how to repair it without being there to view what is going on. by what you are saying, it looks like you have a short between two or more wires, possibly stuck together from heat. After switching off, remove cover at the back and follow the wiring to the clock and the burner switches and look for anything obvious. Look for a wire possibly burned off and leaning onto another electrical wire.
3helpful
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
1helpful
GE electric stove problems, our stove has 3 small burners and one big burner. When we use the big burner at medium heat it does fine then all of a sudden it starts glowing bright red and burns whatever is...
Replace the infinite heat control switch for that burner. (the burner switch that you turn with the knob to select the temp setting) If you list a full model number (usually behind the lower drawer panel on the frame of the range) I can look up the part number for you. It is not a very difficult repair.
7helpful
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
3answers
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
1helpful
2answers
Kenmore electric range 911.9369181
F8 Failure of Electronic Range Control (ERC) Replace Electronic Range Control/Clock (ERC)
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Top Kenmore Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
