My application ran error in the machine, then I take off the bettey, and plus it again.
terrible thing happen, the machine cannot be powered on, whatever I do, it just show nothing. what can I do?
when I plus charger, the red light is on, but I still cannot power on it. pls, help me~~~since the machine is not mine~pls help
It is commercial icemaker, you just call for service and claim the cost against your taxes. It may need refrigerant gas. Once the ice is made and it is ready to harvest, the cycle reverses and heat is directed to the grid to drop the ice. Harvest time is set to 3 1/2 minutes, then it trips out.
You still have something caught in the drain line on the machine. Check the filter again and the lines coming from the tub to the pump, and from the pump to the waste line. Here is a link to LG's document on the "OE" error.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
This happened to me once because my system ran out of resources. I closed everything that is running in the taskbar and applications that are not important like widgets and items that are not important in the device manager then ran again the antivirus. This also happened in another machine that we almost do not shutdown. A reboot and ran the antivirus and it worked.
