Question about Unitech HT630 BATCH Barcode Scanner
I TURN MY SCANNER ON AND WHAT POPS UP IS HT630 BIOS V2.03 MEM 4608KB > I JUST WANT IT TO BE ABLE TO SCAN BARCODES WHAT DO I DO?
  • 155 Answers
Receiving670: You must load a program to execute it. You can make your program using JobGenerator, or i can help you to develope it. Roberto Martinez [email protected]
Posted on Sep 19, 2011
6ya staff
SOURCE:
Hi all i am trying to use barcode scanner in Motorola MC55 Handheld Mobile Computer. i have installed data wedge from...
Hello, Datamatrix is 2D Symbology. Actually this MC55 is a model with 1D Laser Scan engine. The laser cant scan 2D barcodes, therefore he is not decoding the datamatrix barcode.
You would need an MC55 with an 2D Imager or with Camera to scan 2D Barcodes.
Oct 11, 2010 | Motorola MC55 Handheld Mobile Computer PN...
When I scan a barcode with the Symbol LS 4278 scanner it duplicates the barcode. How can I fix this?
There was probably some kind of ADF Rule applyed, please scan the barcode Set All Defaults and Erase All Rules from ADF Chapter in the manual for LS4278 aailable here http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6983404apdf&sliceId=&dialogID=190394003&stateId=1%200%20190388491
May 03, 2010 | Symbol LS 4278 Barcode Scanner
Scanner displays on a same row in excel how do I get it to automatically move the curser to the next line on my second code scan
If you would like the scanner to drop down to the next line scan the barcodes Scan Options, Data Suffix, Enter from the Quick Start Guide that should have come with the scanner. If you do not have the QRG then download the Product Reference Guide from this link:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=134926365&stateId=0%200%2014579837
The barcodes are on Adobe pages 222 and 223 of 342 in this manual.
Oct 15, 2009 | Symbol LS2208 Handheld
We are using Unitech PT630, HT630 for our stock audit at various retail outlets. we get wrong barcodes while scanning. Most of the times, scanner return only 4-6 charectors or part of the barcode is read...
Algunas simbologias de codigos de barras pueden dar lecturas parciales (como el interleaved 2 de 5). Entonces verifica lo siguiente: el lector laser este limpio, y en la aplicacion puedes restringir la lectura a un numero fijo (8 por ejemplo) para que solo lea codigos de barras de longitud fija. Some bar code symbologies can be read in part (such as Interleaved 2 of 5). Then check the following: the laser reader is clean, and the application can restrict the reading to a fixed number (8 for example) only to read barcodes of fixed length.
May 12, 2009 | Unitech 630D PDT 2.5MBRAM LR CCD SCA
Samsung scx-420f series pcl 6 reads scanner locked.
You can solve this problem by entering TECH menu and then --> Data setup --> Clear all mem. And ypu will be ok :)
Jan 07, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Unitech HT630 BATCH Barcode Scanner Logo
914 people viewed this question
Top Unitech Computers & Internet Experts
Ekse
Jeff
B.Th. Pluijm
B.Th. Pluijm
Are you an Unitech Computer and Internet Expert? Answer questions, earn points and help others
