My nikon sb200 was working but stopped all of a sudden with my nikon d200 camera, don't know the right setting.
SOURCE: Nikon SB600 flash behaving strangely
I have a Nikon SB-600 and a Nikon D200 and noticed that the flash suddenly fired by itself and I discovered that I was bumping the depth of field button by mistake.To get rid of this I went into the flash menu on the camera and switched off the modeling lamp that is set to on by default.
hope this is of help to you.
SOURCE: Nikon SB - 800 LCD Defect
Impact has damaged the LCD assembly .
IF you want it repaired contact the email address below
Berrie Smith Camera Repair
[email protected]
SOURCE: Nikon SB 800 fires but pictures reamain dark
make sure your white balance is set to "flash" on both cameras
SOURCE: Speedlight SB-80DX TTL Flash ideal for NIKON D60?
It works but it's not ideal. The SB-80DX won't support TTL flash on the D60, only non-TTL Auto and Manual. The SB-800 is the most capable flash unit for the D60, but you can get full TTL operation with the less expensive SB-600 or SB-400.
SOURCE: flash is not working for a nikon sb-600 speedlight
zoom the flash all the way in so you can see if the flash bulb is broke
