Sony KDL32EX500 32 in. TV Logo
Anonymous Posted on Dec 27, 2011
I would like to find out what the flashing red light indicates.I would like to download the manual.
Anonymous
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 76 Answers
  • Posted on Dec 28, 2011
Anonymous
Expert
Level 2:
Filmmaker:
Answers
76
Questions
Helped
20094
Points
248
Hi nett1611,
First of all, thank you for posting your question here at Fixya.
Please email me at [email protected], I will send you the copy of the Sony KDL-32EX500 Service/repair manual. It is a pdf file format and can't be uploaded here.
Thank you for your patience.
Have a great Holidays!!!
Ratings and feedback are highly appreciated!!!
Mjsazon
Where can I find a User manual for Currie electro drive scooter? Someone cleaned out their garage and gave it to me. I get a red flashing light when I plug it in.need more info.
I did not notice code list but here is a manual, hope it helps.
Plug the battery charger into a wall outlet, then into the charger port on the side of the scooter. The indicator light on the face of the charger will turn red, showing that charging has started. When charging is complete, the indicator light will turn green. A full charge will take 6-8 hours, however if the battery is not empty charging may take much less time. Always unplug the charger after use. Always store the scooter with the power switched turned OFF
http://www.currietech.com/dealers/wiki/images/a/a0/Owner%27s_Manual_-_EZ2_Nano.pdf
download manuals
https://www.yumpu.com/en/document/view/37650434/download-owners-manual-currie-technologies
Why have I got a red light on the bottom of my shaver when I am using it
It is common for many Braun shavers, that if the indicator light flashes red while the shaver is being used (switched on and running), it means the battery is low and needs to be charged soon.
Below is an example from a manual for a Braun model 7526 shaver. You can search that site for other manuals if this is not the correct one.
This model shaver has 3 indicator lights:
1) Green (Charging)
2) Red (Low battery)
3) Blue (Power cord attached and plugged into the wall)
Download the manual for the model 7526 here: http://www.manualslib.com/manual/20281/Braun-5301.html#manual
"The green charging light shows that the
shaver is being charged. When the rechargeable
battery is fully charged, the charging light
flashes or goes off.
If later on, the charging light comes on
again, this indicates that the shaver is
being recharged to maintain its full
capacity.
The red low-charge light flashes when the
battery capacity has dropped below 20%,
provided the shaver is switched on. The
remaining capacity will then be sufficient
for 2 to 3 shaves."
Model 2461 - "check
Power light indicators on flashing red as warning that battery is almost depleted of functionality. ascertain that devices with extension cables deriving power from elsewhere are plugged in to reattain power to acheive regular functionality. For example, devices with red light indication as power warning would also flash yellow or green when in full power charge from another source. refer with devices user guide or manual for refering, diagnostics.
1helpful
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
4helpful
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
1helpful
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Red dye reduction
You can find your manual here....www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/man_c725uz_e.pdf
You find how to disable red eye function on page no: 63 in that manual.
For quick reference i am giving the details briefly,
The flash modes are as follows:
AUTO FLASH:
Automatically fires in low-light and backlight conditions.
RED EYE REDUCTION FLASH:
This mode significantly reduces
the phenomenon of “red-eye”
by emitting about 10 preflashes
before firing the regular
flash. This mode works the
same as the auto-flash except
for the pre-flashes.
To change between flash modes:
1 Press the (flash) switch.
● The flash pops up.
2 Press the / (flash mode) button
repeatedly until the desired flash mode
indication appears.
● The flash mode changes ,
● If / is not pressed within 2 seconds after the selection screen is
displayed, the selection screen disappears.
● To de-activate the flash (Flash Off mode ), push the flash back into the
camera.
3 Press the shutter button halfway.
● When the flash is ready to fire, the
(flash stand-by) mark lights.
4 Press the shutter button all the way.
● The flash fires.
Hope my info solves your problem,
Thanx for using fixya,
Good Luck.
2helpful
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
2answers
Red light flashes
First go to this link; http://www.panasonic.co.uk/customer-Support/download-centre.asp Type in NV-MX7 in the search box And select the correct version of the NV-MX7 that you have you will be able to download a user manual which will hopefully tell you how to deal with the problem. If you have no luck finding a solution in there then please post back with the model version and I can hopefully help (all the versions have some different fault indication lights) and differences in the tape loading system. Hope this helps - please post back with model details :)
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
