Question about Braun Health & Beauty
Why have I got a red light on the bottom of my shaver when I am using it
  • shaveroutlet.com
    shaveroutlet.com Dec 02, 2015
    What is the specific model number?
Kevin Fegan
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
It is common for many Braun shavers, that if the indicator light flashes red while the shaver is being used (switched on and running), it means the battery is low and needs to be charged soon.
Below is an example from a manual for a Braun model 7526 shaver. You can search that site for other manuals if this is not the correct one.
This model shaver has 3 indicator lights:
1) Green (Charging)
2) Red (Low battery)
3) Blue (Power cord attached and plugged into the wall)
Download the manual for the model 7526 here: http://www.manualslib.com/manual/20281/Braun-5301.html#manual
"The green charging light shows that the
shaver is being charged. When the rechargeable
battery is fully charged, the charging light
flashes or goes off.
If later on, the charging light comes on
again, this indicates that the shaver is
being recharged to maintain its full
capacity.
The red low-charge light flashes when the
battery capacity has dropped below 20%,
provided the shaver is switched on. The
remaining capacity will then be sufficient
for 2 to 3 shaves."
Posted on Dec 05, 2015
Diagram for norelco 3605x Took apart to replace battery and red plastic item fell out and I do not know where it goes Help please.
The red piece is the voltage switch. It allows you to use your shaver to be used with 120V or 220V by moving it into the corresponding position.
This piece fits in at the bottom of the shaver with the notch showing out of the tiny 'window' at the bottom. The metal prongs will situated so that they make contact with the circuit board.
ShaverOutlet com The Ultimate Shaver Source
When fully charged the red light comes on immediately and the shaver does not start.
Use your warranty to have it repaired. Either the charge circuit or the batteries are faulty.
How much voltage does a philishave 805 electric shaver have?
Your shaver can be used with either voltage. There is a red switch on the bottom where the cord plugs in. Move it to the voltage needed
14helpful
2answers
What does a flashing red light at bottom of display when you turn razor off mean looks lit the 3 rotary blades
It means they want you to buy a new shaver head. U dont need too, and the light will automatically go off after 7 shaves from when it first came on.
1helpful
My Phillips arcitec has a red light blinking at the very bottom of my shaver. I've had the shaver for 3 years.
It's means that you change new replacement heads. That philips arcitec 1060 electric shaver replacement heads is Norelco RQ10 shaving heads.
1helpful
2answers
After using the shave a digital red symbol of the head shows up at the bottom of the shaver. What does this mean? Thanks.
Digital red symbol of the head shows up. It's menas that you should change new replacement heads, that Norelco Arcitec electric shaver replacement heads is Norelco RQ10 shaving heads.
1helpful
3answers
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
4helpful
Red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
2helpful
3answers
Charge
How long have you had the shaver? If it has been a couple of years, then it sounds like the batteries are exhausted.
The batteries can be replaced, although it's not as easy as changing them out of a flashlight. There is a way to disassemble the shaver and change the batteries. They are soldered in place at two basic points. If you obtain replacement batteries (on eBay you can get them for about $12 a piece), you can perform the replacement yourself:
Opening a Braun 7000 Series Shaver
1) Find a thin metal object with no sharp edges (such as a nail file). Use your thumb and pull on the bottom end cord socket part, enough to cause a gap between it and the back shell. Insert the metal object into the gap in the center of the part. THEN pry it off. If you use a regular screw driver, you will likely cause gouges in the plastic. And the best leverage is in the center.
2) The silver side parts are held on by two tabs at the top. With the bottom piece gone, the side parts swing off easily. Don't worry about keeping track of which sides the silver trim pieces go on, as they're designed to fit on only one side (you'll see the cutout for the shaver head stem is off to one side).
3) The case is held together by 4 small torq screws. Use a torq screwdriver--do not attempt to do this with anything else. Be careful to turn the screws slowly, so you don't strip them.
4) With the screws removed, the two halves of the shaver will come apart. The remaining parts can be extracted without any special tools. Keep note of how they are removed, as assembly will be the reversal of removal.
5) Note that if you are replacing the batteries (there are two of them), you will need a soldering iron to detach them from the circuit board, unless you're replacing the whole part.
6) Reassembly is pretty much what you expect--the reverse of disassembly. However, the bottom cord socket part is tricky to get put into place. Pushing straight down on this part will not get it to go in, nor any other obvious way. It's best to get the prongs inserted on one side, then while pushing in on the prongs of the opposite side, apply pressure on the top side surfaces. The part should snap right back into place.
Health & Beauty Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
reference30
Michael Thomas
Michael Thomas
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
