Please explain exactly what it does..If it does start but stay on the logo screen it means it need an operation system ..or the operation system does not load cause the settings were changed in BIOS ..and teh ahci function is on and iot has no driver ..In this case the action to be done is to go to BIOS settings by pressing f2 on start .. open the first tab and locate the ahci function .and disable it ..and let it run ide compatible ..save teh changes with F10 and restart ..This will make it work if it has a good operation system on .if it does not ..you have to load it again ..and do this using recovery partition or disk .or just use a normal boot-able disk with the operation system you want .start with the disk in ..hit f12 to sel;ect the boot from disk ..and enter to continue ..If you are asked ..press any key to confirm the action ..and go with the installing ..
