20 Most Recent
Toshiba Satellite L875ds7332 Notebook Laptop Questions & Answers
Dvd player isn't working properly
The most common issue associated with this is the incorrect placement of the wiring with reference to the input on the tv. Simply put, ensure that the colours of the cables are the same with the points in the tv or monitor that you're putting them into.
Good luck, if you need more assistance let me know
Toshiba...
Answered
on Jun 01, 2014
Laptop cursor not working
Lets see, there could several issues, however the most common is a faulty or missing driver. Depending on the specifications of your mouse (Cursor) you can search for a driver in google by entering your make and model or if it is a mouse that is on the computer (not external), search using the Laptop make and model followed by "mouse driver".
Good luck and let me know if you require more assistance
Toshiba...
Answered
on Jun 01, 2014
Hdmi not working
Interesting. Ensure that the monitor you are connecting to is powered on and that the power source is secured and working. Furthermore, check to see if the default monitor is recieving or recognising a connection
Toshiba...
Answered
on Jun 01, 2014
What do I do?
Are you still able to go into bios? If so check the boot order to see if you have your cd/dvd rom first or your hard drive.
Toshiba...
Answered
on Jun 01, 2014
Toshiba l875d-7332
try doing the hard reset; remove battery and ac adaptor and press the power button for 30 sec; after that reseat the battery and the adaptor and power up the laptop.
let me know if that is working for or not.
Toshiba...
Answered
on Feb 09, 2014
Black screen , power light and fan
I assuming by your very limited question information that your computer is on and the fan is turning and windows is or was loading to the log in screen but never showed. to make this easier post a video clip so I can see what is actually happening.
Toshiba...
Answered
on Oct 03, 2013
Toshiba satellit L875d-s7332 froze during factory recovery now says no bootable device
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Toshiba...
Answered
on Feb 06, 2013
