How do i install it into my Mitsubishi eclipse, i have an Infinity 6 CD changer, but i'm looking into getting a new deck. So do you have any recommendations on decks, ones you can hook up your iPod to, and can you give me instructions on installing my Amp and Sub?
SOURCE: will one of these disc changers hook up to the new decks?
According to the manual at sony's web site, the sony cdx gt520 deck does indeed use RCA style hook up cables.
SOURCE: need help in installing amp.
depending on the power consumption of the amp u will need to run a 4-12 ga wire to the positive battery terminal. then u need to ground it with a wire connected to a clean ground like a chassis bolt. next u need preamp outputs on ur deck to send audio signals to the amp. lastly u need to hook up a remote wire to the blue wire in ur cd player harness
SOURCE: MTX TC2002 amplifier has a noisy gain control
Not really, other than sending it to MTX or an authorized repair shop.
SOURCE: Amp Problems
Unplug the stereo input signal from the amp. If the amp does not do it with the wires unplugged, you may have a problem with the radio sending too much voltage to the input of your amp causing it to go into protect mode. If it continues it is in your power source to the units. Let me know and I'll see what Ii can do. Hope this helps...
