Heating & Cooling Logo
Loretta Trezise Posted on Dec 07, 2011
I have a YKR-F/06 remote control and only the power and swing buttons are working. Not good as it's stuck on 24 degrees and need to cool our bedroom down. Anyone know where we can buy a new remote fro
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Sep 20, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5941
Points
16
Http://www.codistec.com/en/remote-controls-for-air-conditioning/77-remote-control-ykr-06.html
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4145
Points
Try to change the cell. U can repair it.
  • Anonymous Dec 07, 2011
    try to change the cell. U can repair it.
1helpful
Brand new batteries, but display on YKR-F/06 remote only now and then shows anything, which disappears soon as any button is pressed.
Most problems like this are poor power supply. First thing to do is try another new set of batteries, you would not be the first person to get faulty batteries out of a packet. (do you have a multi meter to test them?)
Then:
Are the battery terminals clean and corrosion free, this is often a problem when batteries have leaked in the remote. In some cases I have seen leaked batteries corrode the device's terminal badly enough the terminals need to be re-manufactured.
Check the terminal are reaching the battery surfaces with a bit of tension on them. Some batteries have flatter terminals so the device's contacts don't reach them solidly. You may be able to use tweezers or similar to stretch the device's terminals.
If both of these steps check out it is possible your device has a broken/cracked solder joint securing the device's terminals to its circuit board. You may need someone to disassemble & repair the remote.
1helpful
Torion ta14 unit where does the water go to fill
This is not Refrigerator This is Air Conditioner
you wrong category
This is the specs for you unit:
4.0kw Portable Air Conditioner (14,000btu)
Including Flexible Window Kit
Benefits:
• Suitable for any bedroom or small living
• No Installation Required
• Timer On/Off
• Remote Control
• 3 Speed Fan + Dehumidifier
• 3 Year Replacement Warranty
Specifications:
• Cooling Capacity: 4.0 Kw (Cooling Only)
• High Air Flow 570m3
• Plug Type: 10A
• Control Type: Manual Buttons or Fully Remote Control
R410A Gas
The last is the KEY. the unit don`t work with water works with GAS R410A
This is compressor type Portable Air Conditioner
5helpful
2answers
Need instructions for remote AUX ykr-f/06
anyone have a manual book for a remote control aux ykr-f/06 cant set the timer could anyone scan and send a copy to [email protected] plez
1helpful
I have a conia YKR-F/06 air con & my remote wont work, can u turn it on from the unit itself?
Some units having manual button in unit itself. But you can't change temp setting or mode setting by that. It's advisable to get new remote and operate this. Thanks.
20helpful
3answers
Need remote control codes for the JVC Multi Brand Remote Control Unit, LP20303-018
It took me a week to find the right instructions and codes on how to do this so I am posting it everywhere I can to help out folks with the same remote. Pay close attention to the instructions, for instance when programming the remote for TV use make sure you hold the TV button down while you enter the code and then press OK, You also have to hold the TV button down while you use the volume and channel controls or it will just change the VCR channel.
A
Turn on TV
Turn on the TV using the Power button on the TV or its Remote.
B
Set TV brand code
A
Press and hold TV.
B
Press MBR SET.
C
Press the Number keys to enter your TV.s brand code.
D
Press OK, and release TV. The TV should turn off.
C
Operate TV
While holding down TV, press one of the following buttons:
POWER 1, TV/VCR, TV CH+/., ^(TV Muting), TV VOL+/.,
and the Number keys.
For some brands, you must press ENTER after having pressed the
Number keys to enter a channel number.
TV BRAND CODE TV BRAND CODE
JVC 01, 03
SONY 07
HITACHI 10
SAMSUNG 12
MAGNAVOX 02
SANYO 13
MITSUBISHI 03
SEARS 13
PANASONIC 04, 11
TOSHIBA 08
RCA 05
ZENITH 09
SHARP 06
Cable Box or DBS Receiver Brand Setting
A
Turn on cable box or DBS receiver
Turn on the cable box or DBS receiver using the Power button on
the unit or its Remote.
B
Enter brand code
A
Press and hold CABLE/DBS.
B
Press MBR SET.
C
Press the Number keys to enter your cable box.s (or DBS
receiver.s) brand code.
D
Press OK, and release CABLE/DBS.
C
Operate cable box or DBS receiver
While holding down CABLE/DBS, press one of the following
buttons: POWER 1, TV CH+/., and the Number keys.
To change the cable box.s (or DBS receiver.s) channels, press TV
CH+/–
or the Number keys. (The CH+/–
button can be used to
change the VCR.s channels only.)
CABLE BOX BRAND CODE
ARCHER 01, 05, 17
CABLETENNA 01, 17
CABLEVIEW 15, 16, 17, 21, 25
CITIZEN 15, 16, 17, 21, 25
CURTIS 02
DIAMOND 01, 17
GC BRAND 15, 16, 17, 21, 25
GEMINI 15
GENERAL INSTRUMENTS 01, 04, 06, 11, 12, 15, 28
HAMLIN 10, 18, 23
JASCO 15
JERROLD 01, 04, 06, 11, 12, 15, 28
NOVAVISION 02
OAK 07
PANASONIC 13, 14
PULSER 15, 16, 17, 21, 25
RCA 13, 14
REGAL 10, 18, 23
REMBRANDT 01, 16, 17
SAMSUNG 05, 16, 24
SCIENTIFIC ATLANTA 02
SIGMA 07
SL MARX 05, 16, 17, 24, 25
SPRUCER 13, 14
STARGATE 05, 15, 16, 17, 21, 24, 25
TELEVIEW 05, 16, 24
TOCOM 01, 04, 16
UNIKA 01, 17
UNIVERSAL 16, 17, 25
VIDEOWAY 03, 09, 22
ZENITH 03, 09, 22
DBS RECEIVER BRAND CODE
JVC (DISH Network) 51
ECHOSTAR (DISH Network) 51
SONY (DSS) 41
RCA (DSS) 40
Changing Remote Control Code
This Remote is capable of transmitting two control codes; one set
to respond to A code control signals and another set to respond to
B code control signals. This Remote control is preset to send A
code signals because your VCR is initially set to respond to A code
signals. You can easily modify your VCR and the Remote to
respond to B code signals. When using two JVC VCRs, set two
VCRs and their Remotes to different codes, so that you can
operate these VCRs separately.
A
Set remote control code for Remote
A
Press and hold A/B.
B
Press the Number key .2..
C
Press OK, and release A/B.
The Remote now can transmit B code control signals.
B
Check remote control code for VCR
Press and hold 4
on the VCR for more than 5 seconds while the
VCR is turned off. The code currently set appears on the display
panel.
C
Change code for VCR
Press any key on the Remote. The VCR now responds to B code
control signals.
To set the Remote and the VCR back to A code control signals,
repeat the same procedure as shown above except pressing the
Number key .1”
in step B
of 1
1111.
To control two VCRs with the same Remote
You can control two JVC VCRs by switching the remote control
code for the Remote between A and B (.
step A
AAAA), keeping two
VCRs to different control codes.
To change only the remote control code for the Remote, DO
NOT perform steps B
BBBBand C
CCCC.
One of the remote controls seems to be stuck
sounds like to have a stuck button try another remote.
Top Heating & Cooling Experts
Paul Carew
john h
