SOURCE: my presario sr1720nx says disc
remove your cpu cover reove the molex conecter ie power connecter and refix them do the same with ide or sata cable the power connecter may be loose or ide connecter or sata cable may have fault
SOURCE: HP a6750f PC refused to
Here these guides will help you!
How to Remove the Side Panels of My Computer Chassis!!!
How do I reset my BIOS/CMOS to defaults?
My Computer is not turning on!!! Is it dead!!! No POST!!!
If it is under warranty take it back for a replacement computer, or they can replace the faulty component free of charge.
May-be resetting the BIOS/CMOS will bring you some joy, tell me how it goes.
Happy testing
damnor01
SOURCE: I just installed a hard drive that I know works
If your HDD is being detected it is good. You did the right thing. There is a possibility that it could be the power supply. It is not providing enough power so the system reboots. If you have 2 HDD's connected try removing one of them. If your pc is connected to a power strip or a surge protector, try connecting it directly to the wall outlet.
Testimonial: "Thatks sooo much, I would never have thought the power supply could have caused this issue...Thanks again!!!!"
