Remove hoses and check for cloggs
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Your water valve must be bad. Get you a cheater cord and unplug the water valve soles. Apply direct power from the wall to each solenoid is what i would do to make sure the water valve is ok.
Bruce have you had the case off?
Here is my page on these washers:http://sites.google.com/site/sublimeappl...
Sound to me like yall need a new valve.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
heatman101
I checked and cleaned screens some rust on screen in cold water inlet none in hot water inlet made no difference.
I went back and removed the screens which I cleaned out before, this time it worked
but now with the machine off the cold water continues to flow into the washer
slowly.Unplugged the power cord to the washer did not stop it.
I have not had the case off yet I will get back with you I really appreciate the help
