Toshiba 36A43 36" TV Logo
Anonymous Posted on Oct 30, 2011
Tv wont stop scanning between tv, video1, video2,video3
Level 3:
  • Toshiba Master 17,130 Answers
  • Posted on Oct 31, 2011
Toshiba Master
Level 3:
Answers
17130
Questions
0
Helped
3635724
Points
52372
Possible there is a sync issue as the return pulses do not come back to lock the scanned channels. This can be an issue which can vary from a simple loose connection to a fault iin the signal processor. This would need the help of a serious probe with a signal tracking using a scope and assisted equipments. Take consensus as this can be tricky before you tamper the board.
Pip now is on the souce menu whereas cable, video1, and video2 were there before. How do i get rid of pip and return to the former sources?
close the pip window first
if your tv/video button on your remote brings up
an input selection menu either press the number
of the ones you want or use the chan^chanv buttons
to select
We understand that your problem is: I have a Panasonic PT-53WX42 53 and I am trying to connect with the component connection but it will not cycle through component connection Just cable, video1,...
This problems,most of the times component cable are old and time passing and wheather conditions is ur ememy.Replaced the RCA component cable and do a hard reset the tv by unplug,replug it back like about and hour later.Go into ur tv menu and tries every setting to resetting back to the factory setting,this problems.Should be solved.
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
3helpful
TRying to get my PC to TV converter up and running
I just purchased the Kworld 1600 PC to TV Game Box today. I also had the same problem as many others seem to have had. The TV screen displayed only colored bars. After searching on line for troubleshooting ideas I finally was able to correct the problem, thanks to help of people responding to these problems on "FixYa", and I thank you, as I was ready to return the product at a loss of 15% of the cost (restocking fee).
I am using a Toshiba Satelite L350D with Vista Home Premium and a 2005-32"JVC TV.
First ensure that the Monitor Y-cable supplied has been properly installed to your PC and your TV (my first mistake). Each plug is individually identified, that being, TV, monitor, scan cnvtr.
Second, on Vista go to Control Panel, open (Double left click) the personalization icon. You can then open your display settings.click on advanced settings, this will open a window for your graphics card. Click on "List All Modes", use an 800 x 600 High Color Mode, 16 bit, 59 or 60 hertz, hit 'OK' and that window will close.Then hit 'Apply' in the Graphics Card window(the screen will go black and then set itself to the new mode). You may have to try a few different 800 x 600 modes to find the best one for your TV.
Thirdly this converter is only for video, not audio.
For audio you must use a 1/8 stereo plug from your PC headphone jack to an RCA adapter into the Left and Right Audio Input of your TV.
Make sure you are using the same Video Input Section for both your audio and video (Video1, Video2, Video3, you cannot plug the video into Video1 and the audio into Video2).
After setting this converter up on my Laptop I was also able to plug it into my 7+ year old desktop (Cicero P4, XP Home Edition).
I hope grouping these 3 problems into 1 will help others and save them some time and frustration.
Thanks again to everyone on "FixYa" for their help.
1helpful
Car dvd
I called Sony and they zipped me right through it, without asking for a credit card! They have fantastic customer service! Just for that reason, I will continue to purchase Sony products!
Power up your player by pushing the power button on the screen. Press input, then press the down button on the left, selecting NTSC for all inputs (Video1, Video2, Video3, and Video4). Your screen will immediately flip back to color and be as good as new!
The fix was so easy! Hope it works for you too.
2answers
Connevting to an LCD TV
This will vary by TV model, but some televisions route external signals to a separate video setting, often only reachable through the remote. Try looking for a "video" or "input" or "mode" setting on your remote. On my TV it's a "video" button that toggles from channels to Video1, Video2, Video3 and Svideo, then back to channels.
If that doesn't help you, let me know the exact make and model of your TV and I might be able to find something more specific.
-Dyllan
Colors are out of tune
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Can't get componet Video to work
Make sure you have an input Video signal on that Yamaha Reciever (exa. DVD, Cable box, etc...) then choose the right input selection on ur receiver (Video1, Video2, AUX, etc..), then connect ur TV on the receiver Monitor Video out. And put your TV on the right VIDEO input too (Video1, Video2, AUX, etc..). Goodluck
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
