20 Most Recent Zenith A27B33W 27" TV Questions & Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Zenith A27B33W... • Answered on Mar 10, 2017
Read the comcast instructions and do a 'Search' for the code rather that trying to look it up on the list. It takes a few min but works every time for me.
Zenith A27B33W... • Answered on Nov 16, 2013
0038,0031,0036. Try these codes. For more information, check these links. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/
on the back side of set should have a control that says vertical size/ sweep. it is recessed into a small hole or has protruded knob, if so used a small flat tip common screwdriver for the adjustment. make sure you can see the control knob or slot clearly otherwise you could short out something!!!!!
Zenith A27B33W... • Answered on Sep 21, 2009
I found a similar problem with another Zenith tv and it sounds pretty close to the problem stated above. This was threir solution to it...
REPLACE all 3 caps; 560pF 2KV p/n 22-8386-05 (Buy from Digi-Key good parts) even if one still looks good, very common failures and 9 out of 10 times if
the H.O.T. is also shorted the Fly should still be good.
Hope it helps
Zenith A27B33W... • Answered on May 04, 2008
This is infact a thermistor. Can you read any of the numbers on the part itself? I don't have the service manual for this model.
Dan
Zenith A27B33W... • Answered on May 01, 2008
close the pip window first
if your tv/video button on your remote brings up
an input selection menu either press the number
of the ones you want or use the chan^chanv buttons
to select
Zenith A27B33W... • Answered on Nov 30, 2007
A common practice in the TV industry is to include the size in inches in the model number. Often, a model will be made in different sizes, for example, z42pj240 may have a z50pj240 family member. They will use the same main circuit boards and remote controls. Check the list in your universal remote control manual for a variant like that.
Zenith Televison... • Answered on Mar 29, 2021
If you are trying to use the player and switch between DVD and VCR there is usually a button on the front of the player and a matching one on the remote. VCRs are becoming very rare now so most TVs don't have the connectors for them. How old your TV is will control how you do this. Older HD TVs are fitted with a SCART connector, ( a large, chunky, rectangular connector with lots of pin holes), or RCA connectors, (3 round pin connectors coloured red, white and yellow). *Note* Make sure you use the 'OUT' connectors on the VCR and the 'IN' connectors on the TV. Some newer TVs will let you connect through a 'screw in' Satellite/'CABLE TV wire connector.
Zenith Televison... • Answered on Nov 20, 2020
1) tune the desired station frequency
2) while the frequency is being displayed, quickly press the memo set/clock adjust button.
3) press the desired preset button
4) press the memo set/clock adj button again
5) the station will be stored
Zenith Televison... • Answered on Apr 24, 2020
To set the Alarm press the Alarm Set button then use the set buttons on top change the Alarm time. Use the to change the Alarm time, when the Alarm time is set press and hold enter until you hear a beep. Press the Alarm On/Off button to select radio or buzzer for the alarm or alarm off. http://portablemedia.manualsonline.com/support/zenith/clock-radio/zenith-1233a-how-do-you-set-the-time-on-the-clock-4514622
Zenith Televison... • Answered on Apr 23, 2020
Digit Zenith TV Converter Box Remote Codes
212
254
267
357
454
457
557
657
757
857
955
957
991
4 Digit Zenith Converter TV Box Remote Codes
1415
9910
5 Digit Zenith Converter Box TV Remote Codes
01414
51415
Zenith Televison... • Answered on Apr 22, 2020
Televison & Video Logo
15 questions posted
Top Zenith Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
television
  • Televison & Video
