You may have hit a certain combination of keys on your Gateway laptop and turned on the NumLock function accidentally. The result is that the rectangle of keys from the 7 key down to the question mark key have become a number-entry keypad. Worse, Gateway manuals don't discuss this function.
Hold down the "Fn" key on the bottom row of the keyboard, and press the "NumLk" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F11" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the F11 key and "Scroll Lk" key simultaneously. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F9" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "Scroll Lk" key. Type the letters UIO. They should come up as letters. If none of these help, then it's probably a keyboard malfunction and you'll need to get it repaired.
it will be stuck in roller cleaner mode, that is mechanical. the only real way is to push it thether over to the left. with the power off the printer, then close the compartments and turn on the printer it can take 2 o3 goes as it will try to move it right. you have to get it off the clip that is holding it there. the cartridge is held in place to stop it moving while the roller is cleared.
I would power off the computer and continously hit the space key for a few minutes. It might have a liquid spill such as a soda pop under it and causing it to stick. If that doesn't solve the problem you might need a new keyboard or go inside the laptop and remove the keyboard cable and plug it back in to reseat it. Sometimes that helps. Here's a fail safe alternative. Bring up google's website www.google.com and in the search box type "download.cnet.com" (without the quotes) and click the link to go to their site. When the site comes up look immediately to the left and you will see a gray area that says Find Software. Type in "free virtual keyboard" (without the quotes) and click the mirror to search. It will bring back a page and the Free Virtual Keyboard is listed first. Look to the right of it and click the Download Now button. Download and install it. Once it is install you can look in Start/Programs and right click on it and select Pin to Start Menu then right click again and select Desktop (Create Shortcut). It's a neat keyboard to have just in case your real keyboard goes bonkers. You simply click on the letter with your mouse pointer that you want. It has all the functionality of a physical keyboard. You can open a web page, place your mouse in the address line then bring up the virtual keyboard by clicking on it from your desktop or start menu and it will sit on top of whatever you were trying to do. You can move it to see the typing area as you click on a letter. It works the same way if you opened a word document. In your case anytime you need the space bar, just click on it.
This indicates the ' 0 ' key is stuck, not mechanically, but the contacts.
One thing you can do is disassemble the keyboard and try cleaning between the two transparent sheets (with contacts) where the contacts for the non-working key is.
If this does not solve the problem, you can try putting an ' O ' shape cut out of paper. The inside diameter should be slightly larger than the contact area. The 'O' should be placed such that this the contacts for the erroneous 0 key contacts are encircled by the paper O.
If even that fails, put a piece of paper between these contacts so that you won't get the working area filled with 0s. I know it can be headache, but you will get used to using the other 0 key.
In most cases if the printer is asking for an unexpected manual feed it is because the paper tray is not set to the right paper size or type. To set the paper size to the most common size and type (letter size plain paper) use the following instructions. 1. Press theMenubutton. 2. Press the right arrow key untilPaper Menuthen press Check Mark. 3. Press the right arrow key untilSize/Typethen press Check Mark. 4. Press the right arrow key untilTray 1then press Check Mark. 5. Press the right or left arrow key untilLetter then press Check Mark. 6. Press the right or left arrow key untilPlainthen press Check Mark. 7. Press the back button untilReadyis displayed. This will set up your printer tray for plain letter paper and should relieve the manual feed error unless yourcomputeris sending other paper size/type settings.
1. Press the Menu button. 2. Press the right arrow key until Paper Menu then press Check Mark. 3. Press the right arrow key until Size/Type then press Check Mark. 4. Press the right arrow key until Tray 1 then press Check Mark. 5. Press the right or left arrow key until Letter then press Check Mark. 6. Press the right or left arrow key until Plain then press Check Mark.
7. Press the back button until Ready is displayed.
This will set up your printer for plain letter paper and should relieve the manual feed error unless your computer is sending other paper size/type settings.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344. The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming. At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you want to change the name on. Press the show key (top right arrow) The display should say LINE ACCESS Press the next key (bottom right arrow) . The display should say CAPABILITIES. Press the next key (bottom right arrow) . The display say Name. press the Chng soft key. use the dial pad to enter the name. advance using the arrow soft key to go to the next letter ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5 Press the next key (bottom right arrow) to enter the name. Press the release key when finished
