2001 Yamaha XJR 1300 SP Logo
Posted on Sep 17, 2011
Following a major service my tacho is displaying an error code by the following sequence "3000 1000 0, then repeating 3000 1000 0" What does it mean and how can I clear it so that the rev counter functions again?
2 Related Answers
Anonymous
  • Posted on May 22, 2009
SOURCE: Rev Counter indicating fault code
been told its something to do with the fuel sender in the tank. i think a wire come adrift, hope this helps, Uni. From Unitracmotorcycles.
Anonymous
  • 388 Answers
  • Posted on Nov 18, 2009
SOURCE: I have an Y Reg XJR 1300 SP, Rev Counter
This happens every time you first turn the bike on, just before you hit the start switch, right? That's normal...your bike has a "brain" that goes through a systems check when you turn the key.
My Maytag BRAVOS MCT Serial #CY5170277 ModelMVWB750WQ0 has stopped mid cycle.
To retrieve error codes from your Maytag BRAVOS MCT washing machine, you can try the following steps:
  1. Make sure the washer is in standby mode (all lights off).
  2. Select any three buttons (except POWER) and follow the steps below, pressing the buttons in the following order within 8 seconds:
  • Press and release the 1st button
  • Press and release the 2nd button
  • Press and release the 3rd button
  • Repeat this sequence two more times (a total of 3 times)
  1. If the buttons are pressed in the correct sequence, all indicator lights will turn on for 5 seconds and then turn off except for the "lid lock" indicator.
  2. The washer will then start a diagnostic test cycle and the error codes will be displayed in the "Estimated Time Remaining" display.
Note: Make sure to write down any error codes displayed on the screen, as they will be helpful in troubleshooting the issue with your washer.
tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
tip
SERVICE MODE AND ERROR CODES CHECK
Error code H4
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Toshiba studo120 H4 error code
2helpful
Control panel shows "H4"
This is a solution from the Xerox Support website (www.support.xerox.com) Give it a try and hopefully it resolves your problem. Take care & good luck.
Solution: Perform a Fault Reset 14
I am getting an error message "H-4" on my copier. Xerox says that they do not service these anymore. ???
Well if you depend on Xerox service, then you have a problem. They are getting out of the service business. But there are tons of Xerox dealer service and independand service that service that product. But you do NOT need a service call. Do this reset and it will correct your problem. This WILL work.
  8. If the above steps do not clear the error code, repeat steps several times
Whirlpool calypso clothes washer stuck on the "FL" for overfill code - will not reset after hitting stop/cancel or after unpluging - one year ago the customer service for whirlpool gave us the...
Try pressing the following key pad buttons within 5 seconds - PREWASH OPTIONS - WASH TIME, PREWASH OPTIONS - WASH TIME, in this sequence and allow the washer to run. The LED display will start counting down as the washer begins a sequence of short diagnostics tests. If no error is present, the washer will return to standby. If the error persists, you may have a blockage in your drain pump. Please run the test and let me know the results. Total test time is about 1 minute 40 seconds. I hope this helps you.
3helpful
H4 message call service
2answers
Remove error in AR-5316
1helpful
3answers
Sharp copier AR5316
H2 or 2H is related to a fuser under heat or overheat.
Try this first,
If this does not clear the problem the fuser will need replaced.
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
