ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Sharp Fuser H2-0 Fusing unit
temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING
ON MACHINE*** You have to reset fuser errors with simulation 14.
Push P * C * then 14 then Start (the button you use to make copies)
and it should reset the code. If not then replace the fuser. SM
5-1 should turn the lamp on. If lamp blinks on and off it is the
thermistor, if it does not it is the lamp, but check the contacts on
the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective
replace.
Try these steps 1.Press continously #keythen Interrupt keythen CA keythen #
key 2.If the display turns off itmeans
that you are inside the simulation but if not do again step 1.
3.Press 81 then press enter then press 1 then enter
You can not enlarge when set to book copy since the machine is not able to rotate the image to fit on bigger size of paper.you need a machine with rotation feature like the Sharp ar-5127 with a dual function board.
SOLUTION: ERROR MESSAGE U2-40, SHARP COPIER AR-5127 PRESS # PRESS = PRESS C PRESS = TYPE 16 PRESS ENTER BUTTON (the button for making photocopy) PRESS 'OK' TWICE Note: be fast in pressing all the buttons. FROM EKPA ONU - (+2348055790979, NIGERIA,LAGOS)
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
