GE Monogram ZVB36SHSS Stainless Steel Kitchen Hood Logo
Anonymous Posted on Aug 30, 2011
My GE Monogram Vent Hood fan and lights have suddenly stopped working.
  • 1 more comment
  • Anonymous Aug 30, 2011
    Sorry but I posted the wrong model ID. It is a ZV750SY.
  • Anonymous Aug 31, 2011
    As I've already said, the model is ZV750SY, NOT ZVB36SHSS.
  • Blue Hen
    Blue Hen Nov 07, 2018
    Did you replace a lightbulb on the hood? What wattage did you install? It requires a 20W not a 50W. It needs a new fuse.
    The fuse is located ABOVE the hood in the pipe duct.
    Order 8A 250W glass fuse. (1/4" x 1-1/4") GEAppliance part
    WBX02X10646 Range Hood Fuse. They are hard to find.
    Turn off circuit breaker. Remove the stainless steel duct or slide it up to access the fuse box above the hood. Open the black fuse box with screwdriver. Replace the small fuse. Turn on the Circuit Breaker to test the fan, and lights. Turn the CB back off and replace the fuse box cover and stainless steel duct
    Use stainless steel cleaner to remove dirt and grease marks on duct. Turn on the CB for everyday use. Good Luck.
Richard Roth
Level 3:
Top Expert:
  • GE Master 9,472 Answers
  • Posted on Aug 30, 2011
Richard Roth
GE Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2629037
Points
28464
You will need to replace the "control board" on the unit. Here is a link to the part. Here is a diagram of your hood. The part is number 20 on the diagram.
Blue Hen
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 07, 2018
Blue Hen
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4234
Points
Diagrams monogram zv750s
Go to the G.E. Website and the diagrams there.
Ge zv850 vent hood
was this a d.i.y. project, if so was a proper ground ran from breaker usually a size bigger than the power. when the fan goes out does the light do the same, as u may have crossed your device wires. electrical can be tricky because there can be several reasons for your issue. u suggest u double check your work ensuring everything is
1helpful
Ge monogram fan dying slow death...first hi-spd. only, now only humming, lights work...is it fuse, transformer or worse, blower assembly
My best guess is the blower motor is going out -- probably the bearings. You might be able to replace just the motor excluding the propeller or the squirrel cage as the case maybe.
3helpful
GE Monogram ice maker dispensing ice on its own
my best guess is the board in the door.try appliance parts pros.they have the best warrenty on parts.
2helpful
My range stop working
Hi 7764,
I'm Harvey the Master Plumber.
Your problem is: You have monogram (df 8 08989 9) hood it all of a sudden stop working , there is power (120v) coming in ' but nothing works
If you have the testing equipment and the ability then check the fuse then the transformer then simply follow the power till you see where it stops. Or yu might try utilizing the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
22helpful
ZV30SSF GE Monogram Hood Lighting
I found them at http://lightbulbsdirect.com look for
MR1650E26120
JDR Type Medium Base (E-26) / MR-16 2 Diameter Flood / Line Voltage / 50 Watt, they were only $5.99 each. apparently GE charges you $19.50 if you order through them.
GE Monogram Wall Vent zv750SY blower Problems
javascript:launchURL('/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00035500/00035520.p01.pdf')
Ge monogram hood has power but not working
Diana, the tech sheet I have states that if the unit has a power interruption, reset the house circuit breaker to the hood, if made before 2001. If after 2001, serial number beginning with DA press the start button to reset the hood. Let me know if it worked, Catriver..post back.
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
