Thank you for posting your question here on Fixya.com. Spiders have been in the burner tubes and there is enough silk in there to prevent the gas flow down the tube. I use a stiff piece of #8 wire to run up inside the tube to clear out the silk. Along the bottom edge where it slips over the jet you should see a little dip and opening from below the gas manifold. Run the wire up into the burner from there. If there is a lot or a few passes doesn't clear it out I bend a little hook into the tip of the wire. After a few more passes it should clean it all out and the burner tunes should work properly. Confirm this by checking all the flames to ensure they are solid blue and a few inches tall off the burners. If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
