20 Most Recent
Raypak Free Hydraulic Lift Gate Delivery - No L... Questions & Answers
What does CFH mean on your pool heater and how do you fix it?
CFH is call for heat and the flame is about to come up. The banging you hear is the water inside the heater overheating to a boil. What you have is a water flow problem. If you have a valve bridging the water into the heater and the water going out be sure this valve is 80-90% closed so it forces water through the heater. If not you may have a problem inside the water manifold on the side of the heater. Their is a water by pass disc inside the header if stuck open will cause the same problem. Also check your baskets and filter to be sure they are clean.
