An electrical storm, a power outage and other problems can cause a voltage surge to travel into homes and damage or destroy sensitive electronics.
Particularly at risk is the very sensitive CMOS chips used in computers of all sorts and these days almost everything has a computer inside..
These days a radio and a tv are more computer than anything and even the humble toaster contains a small computer.
It is unwise to use a computer without a surge protector to provide some protection against everyday surges, though even very expensive models can provide little protection against lightning induced surges. The best protection is perhaps derived from the herd effect - when over time a household has purchased a surge protector everytime a new appliance was brought into the house and in addition has installed an area surge protector the protection level increases greatly even for "unprotected" devices or appliances.
When the neighbours on the same phase also have a herd of surge protectors you are helping to protect each other.
It is also worth mentioning a surge doesn't always cause something to fail straight away but can cause a weakening effect on electronics so they might fail months or even years later (for no apparent reason)...
Find out what the F03 error is for and then check out the appropriate area. If there was a strike of surge the most likely place to look for damage is the area where the electricity first enters into the device.
SOURCE: bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
SOURCE: Bosch 755 Oven resets during cooking
Hi Jim. Thanks for your request re prob with your oven.
Unfortunately, this is not a problem I have come across before, so in this instance, I am unable to help solve it for you.
Only thing I can suggest at this time is that you check all connections and plug in connectors, you never know it could be caused by a bad or intermittent connection.
Once again, sorry I can't be of more help.
SOURCE: bosch hba34b520
Yes, it is o/k to have a single oven connected to a 13 amp power supply supplied with a 2.5mm cable.
A lot of single ovens already come with a 13 amp plug fitted, so you can plug it straight into a 13 amp socket.
If there is no covenient socket nearby, then you can wire the 2.5mm cable srtaight into the oven terminal block.
I must stress that this only applys to a single oven and not a double one.
Plz rate my solution.
Thanks.
SOURCE: Hi experts. I have a Bosch Oven Model: HBL 745 A
FIRST CHECK FOR ANY BURNT WIRES THEN REPLACE THE HEATING COIL AND TERMOSTATS AND YOUR OVEN SHOULDWORK FINE, BUT MAKE SURE YOU CHECK ALL WIRING FIRST.
SOURCE: bosch 455 oven fan will not stop running.
The fan control unit must have failed. You will need to get it replaced.
