Question about Bosch HBL 742 / HBL 746 Electric Single Oven
Bosch HBL745A Oven door
The door on our HBL745A oven does not close completely at the top. The door is not flush/parallel with the oven, but instaed is at a slight angle, being closer at the bottom of the oven than the top. Seems like an alignment/adjustment issue. Thanks.
Posted by tropxsc on
  • 2 more comments
  • Jdhayes44 Dec 24, 2007
    I have the same issue with a Bosch 455 A Double Oven.
  • Anonymous Nov 09, 2008
    I have the same problem with my Bosch oven door, it does not close tight at the top. We emailed Bosch but had no response. It was only a few weeks old and we complained to the dealer enough that they replaced it with a new one ( after trying to adjust it, replaced the hinges and then replaced to entire door !! ). After getting the new oven everything was fine for about 3 or 4 weeks. Now it is doing the same thing, when using the oven the heat just pours out the top of the doot. You almost need to use an oven mitt to adjust the cook top burners !!! (note: this is a LP Gas oven)
  • muchsnow Dec 13, 2008
    Have a HDS25 series that is the same way. I don't have the slightest idea how to get the door to close on this. been this way since day one.....
    Help......
  • Anonymous Mar 25, 2014
    I took the oven door off without having it on an angle and the bars that hold the oven snapped back & now can't get the door back on
kaizee
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Posted on Jan 17, 2008
Anonymous
    New Friend:
I took the oven door off of my Bosch range and now I can't get it back on. I followed the directions on getting it off and it came right off, no problem.
Posted on Nov 21, 2009
McIrish
Our Bosch convection oven interior is warped which prevents the door from sealing all the way. I use a gungy cord around the handle and hooked to the cabinet, very classy!!
Posted on Aug 26, 2010
jlpatel
    New Friend:
Cheaper fix which I found was to use 2 strong button magnets which are less thicker then the rubber surround and attach these to the frame of the oven.
Posted on Aug 08, 2012
  • jlpatel
    jlpatel Aug 08, 2012
Anonymous
We have a new Bosch stove with electric oven. The oven door shut tight when we got it but soon it wouldn't close all the way. The repairman installed new hinges but that didn't do anything - it still wouldn't close far enough to shut the light off. The repairman then installed a new inner door panel because he thought the old one looked warped, That solved the problem - the door shut tight. That was last week - last night my wife used the oven for the first time since the new door panel. She baked at 325 deg - when she was done, the door would not close any more. It looks to me like the inner door panel is warped again. I will call the repairman today.
Posted on Aug 04, 2009
Anonymous
  • 3 Answers
We have the HBL 742A and have the same problem! We have had it adjusted several times and now our service guy says we must replace the hinges at $145 ea not including labor. Also the door handle has broken three different times and now the convection won't work which may be a circuit board at $300+ not including labor. This is a 3 1/2 year old high end appliance! If you are able to purchase an extended warranty I highly recommend it. We did not and so now looking for a replacement unit (not a Bosch). Good luck and please accept our sympathy.
Posted on Jan 09, 2008
  • cristo76 Oct 11, 2010
    I have a Bosch HGS7282UC-02 30" Pro-Style
    Gas Range, that suffers the common door closing
    problem.
    About a year ago, the range door began not fully closing, causing heat
    to escape, the top to be come hot, and the knobs to suffer heat
    damage. After the problem became worse, I called Bosch and visited a
    showroom here in Brooklyn, but was told that no one had heard of the
    problem. I was told I would have to pay for Bosch to repair the
    problem.
    Despite what I was told by Bosch representatives, I reviewed the
    problem online, with this being a sample post:http://www.farmfreshmeat.com/2009/10/fix...
    I did not want, like others, to pay repair costs for a common
    problem, especially when the costs were frequently a quarter of the
    product's value, and many times did not solve the problem. Why should
    I pay half the cost of the item only to not have the problem resolved?
    Recently, I read in some online discussions covering the door closing
    problem that there is now a sub section on the hinge SKU, indicating
    that there may be a replacement part that addresses the door closing
    problem. If this is the case, I would like to know if anyone has tried the replacement hinges.
    Thanks!
  • chico2000 Nov 10, 2010
    I have a similar problem with my Bosch, which was under warranty. I received a new inside door panel with new hinges, and noted something different with the new insert: the insert is reinforced with a new piece of metal strip behind the hinges. I think this will correct the problem I've been having. As of Nov, 2010, this may be a new fix for Bosch (and Kenmore, and a few other ranges, according to the repair guy) as I received two boxes, one containing a 'kit' to fix the issue, and a second box containing just the insert with this new reinforcement.
    My model number is HES7282U.
    The part number on the work order is "SUB INNER DOOR 22 631 683705 1" AND "SUB FIXING K 22 631 683866 1"
    I think the original problem was the screw on the inner door liner backed out causing the hinge to fail, with the door crashing down. this bent the inner door liner which caused the hinges to not close properly.
Anonymous
    New Friend:
On our oven (Bosch Evolution 700 Series HGS7152UC), the problem was getting worse and worse. I found it is was worsening simply because the hinges had started to come loose. I removed the door as suggested above, and although there are no adjustment screws on this model I tightened the now-loose hinge mounting screws. After tightening those screws it is a lot better, only leaks as much heat as it did when it was new which is tolerable. Still a bad design.
Posted on Dec 09, 2009
I have a Bosch wall oven in my unit but no user manual. The number on the door is bosch hbe632uau/03. Is it ok to close the door when using grill function or will the glass blow out?
if the grill section is behind the oven door then the door should be open
if there is a door for the grill section then the oven door can stay closed
to get a user manual ,go google and type in-- user manual for bosch oven model ( type in what you have) --( or leave it out if it doesn't recognize the model)
If a page is available with a pdf version you can down load it
Oct 19, 2015 | Bosch Ovens
I have a bosch Oven model HBL745A UC and the heating element at the back of the oven won't turn off.
Most likely part is the oven control board, it has relays on it . There is one stuck. IT is 2235 dollars to replace.
Dec 09, 2013 | Bosch HBL 745 Stainless Steel Electric...
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
The door will not close completely
Hi someone lifted up on the door this ishowyou remove oven doors open the door about 1/3 then push down towards the floor it should go back into place, if not you may have to remove it clean the hinges then re-install it , I don't think anyone could have bent the hinges cause that would b very hard to do, but i have seen it done before , get back to me Frank
Dec 04, 2011 | Thermador Professional Series PO301...
Oven door will not close completely no tension.siemens 6 hob.
I told bosch which is the same as siemens that the door hinges are defective. I even told them how to fix the problem without changing the hinges .If you add three washers on each hinge this will bring the door in to close the same for the bosch ranges. ps ex tech:)
Feb 24, 2010 | Ovens
Bosch Double oven - top oven will not open - seems like it is locked
i am not aware of a bosch oven that locks the top door usually only main oven will lock if self clean pyro oven,the small oven never has this feature sounds more like a hinge problem check nothing is fouling the lower part of the oven door.
Dec 30, 2009 | Bosch HBL 755 Stainless Steel Electric...
I need to remove oven door, cant figure out how
drop the door down as low as it will go look carefully at the hinges as they pass through into the oven chassis you will see a clip on each one that you lift up to lock the hinge you usually lift them up as far as they will go then this will lock the hinges as you close the door the hinges will come away from the oven complete with door.... reverse to refit.
May 06, 2009 | Bosch HBL 755 Stainless Steel Electric...
Bosch oven door does not close tightly, takes FOREVER to heat
All you need to do is replace the oven door hinges. as the springs are weak.
It is a fairly straight forward repair to do.
To obtain new hinges, got to:
www.bosch-spareparts.co.uk
or
www.espares.co.uk/bosch
Plz rate my solution.
Thankyou.
Jan 05, 2009 | Bosch HBL 745 Stainless Steel Electric...
Bosch hbn41 ..43
BOSCH COOKER HBN41/43 GLASS ON INSIDE OF OVEN DOOR SLIPPED AND SMASHED
Nov 21, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Oven Door will not close properly
Don't buy Bosh. This is a common problem with them and they are not interested in a fix (ie a thinner door seal would help or adjustment to springs...
Feb 11, 2008 | Ovens
Bosch HBL 742 / HBL 746 Electric Single Oven Logo
11,177 people viewed this question
Top Bosch Ovens Experts
Marvin
Marvin
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
