Question about Bosch Ovens
Bosch integrated oven has a c11 error code. What does this mean please.
Posted by Grainne Carroll on
Tim Heath
    Welcome Back:
    Visited the website for 2 consecutive days.
The Bosch c codes are not error codes. Refer to 'Changing the basic settings' in the manuals, e.g. c1.1, c2.2, c3.2 defaults. They relate to default times for: c1 the time display {1 always on/ 2 off} / c2 timer alarm duration {1 10sec, 2 2min, 3 5min} / c3 set cooking times delay till activation after setting a time {1 2sec, 2 5 sec, 3 10sec}. Pressing / touching the (clock dial) symbol for 4 seconds will activate / save the settings, or power cycling the oven off/on will also cancel this function.
Posted on Feb 23, 2020
Ken Wieczorek
    Sergeant:
  • Bosch Expert
  • 451 Answers
Sounds Like child lock activated check owner manual or send us a model # glad to help more
Posted on Feb 02, 2017
I have a bosch oven with an error code of E0511 can you tell me what it means
Did you google for the code or go to web site to find out just what it stands for? Once you have an idea of what the issue might be you can start doing your thing to fix it.
Sep 13, 2017 | Bosch Ovens
A F04 Err is flashing on my Bosch double oven. Please can you tell me what this means?
The only F04 error on a Bosch oven is with the Bosch 5000 Series wall oven. On this model, the problem is with the door latch. Unplug (or turn off at the circuit breaker) the oven. Turn it back on after a few seconds. When the power comes on, the oven should do a self-test of the lock mechanism. If the error persists, you'll need to do some diagnostics to determine if the lock is faulty. The problem could also be with the wiring or the control board didn't register the correct signal from the lock sensor.
Please add a comment with the model number of the wall oven for more assistance and any possible parts lists. You may want to call for service if you aren't comfortable doing this work. You probably need to get the oven out of the wall cavity for some of the diagnostics.
I hope this helps.
Feb 24, 2017 | Bosch Ovens
Why won't it heat up? And what does error code 311 mean
rcr311w codes Washing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > rcr311w codes
Zita http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3308-bosch-wae-range-washing-machine-fault-codes.html here is one link to error .
Sep 12, 2015 | Bosch HBL5450UC Electric Single Oven
Bosch oven error code E011
My Bosch oven/microwave has error codeE 011 0 006 after cleaning with damp wipe , can I reset it ?
thanks
Yvonne
Apr 07, 2013 | Ovens
How to fix e106 error Bosch oven
Does anyone have step by step instructions on how to clear E106 code on a Bosch self clean oven please.
Thanks Yvonne
Mar 21, 2012 | Ovens
I have error code E106 on my self cleaning Bosch oven
I had same issue - A simple switch off/on at the main breaker for the oven was enough to resolve it.
Mar 01, 2012 | Ovens
Bosch oven function error e124
Can you provide a model number for your oven. Is it a single oven or double ? Wall oven or free standing range ?(conventional with cooking surface)
Unfortunately the error codes for Bosch are different depending on the model of the unit.
Thank you, I`ll look for your reply.
macmarkus :)
Jan 09, 2010 | Bosch Ovens
Wall oven error code
Having the same problem.
Has anyone found a solution to this problem?
Thank you
David
m5beemer(at)gmail.com
Sep 03, 2008 | Bosch HBL 745 Stainless Steel Electric...
Ovens Logo
2,033 people viewed this question
Top Bosch Ovens Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
