20 Most Recent Bosch HBL 742 / HBL 746 Electric Single Oven Questions & Answers
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Bosch HBL 742 /... | Answered on Oct 20, 2013
My husband just figured this out.
- Secure lock nut.
Bosch HBL 742 /... | Answered on Aug 08, 2012
Tip
Common heating faults with Bosch HBL 742 / HBL 746 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 742 / HBL 746 Electric...
On our oven (Bosch Evolution 700 Series HGS7152UC), the problem was getting worse and worse. I found it is was worsening simply because the hinges had started to come loose. I removed the door as suggested above, and although there are no adjustment screws on this model I tightened the now-loose hinge mounting screws. For each hinge there are three screws altogether: two (phillips heads) on the bottom of the door and one (torx head) on the inside wall of the door. After tightening those screws it is a lot better, only leaks as much heat as it did when it was new which is tolerable. Still a bad design.
Bosch HBL 742 /... | Answered on Dec 09, 2009
Most likely the temp sensor is faulty. If temp sensor is accurate, than heating element is bad, or there is not enough correct voltage to the heating element.
If only happens in some modes but not others, than the control panel board may be faulty.
Bosch HBL 742 /... | Answered on Oct 12, 2009
REPAIR IS NOT POSSIBLE BUT REPLACEMENT IS BUY A NEW SWITCH
Bosch Ovens | Answered on Jul 03, 2020
WELL THEN TURN THE ONE THAT LOOKS LIKE A CLOCK AND SEE WHAT YOU ACCOMPLISH
Bosch Ovens | Answered on Jul 01, 2020
Certainly the hinge(s) are replaceable though while some are simple others are a major dismantling job - needing to take the assembly back to the point the hinges were originally fitted.
Parts list and diagram can be found on the link below.
https://www.bosch-home.com/us/supportdetail/product/HBL5032AUC/01#/Tabs=section-spareparts/
Bosch Ovens | Answered on May 18, 2020
Sounds Like child lock activated check owner manual or send us a model # glad to help more
Bosch Ovens | Answered on Feb 23, 2020
then call a local repair service . we can not see it from here
Bosch Ovens | Answered on Jan 10, 2020
E118/E218 Four possible causes.
Reversed high and low speed wires
Hall effect sensor not seated properly
Wire routing coming in contact with the rubber end cap on the cooling fan
Upper plenum coming in contact with the rubber end cap on the cooling fan
Bosch Ovens | Answered on Sep 09, 2019
Bosch HBL 742 / HBL 746 Electric Single Oven Logo
15 questions posted
Top Bosch Ovens Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
View Most Popular
Bosch Ovens
  • Bosch Ovens
Most Popular Question
bosch hbl745a oven door
  • Ovens
