SOURCE: Kitchen Aid KESC 307 hbs4 electric range control
oven not workin very well might be a control issue, but top elements work completly seperate from oven control, and theres 2 electronics there $200 for touchpad galss assy and $375 for electronic timer, and switches for the burner might be 50.id make sure I trusted the repairman's diag before proceding
CESAR, THE OVEN CONTROL IS THE CLOCK,HOWEVER, ON MANY KITCHEN AID RANGES, THERE IS AN INLINE FUSE 15AMP, THAT IS IN THE OVEN CIRCUIT. I WOULD SUGGEST THAT THE INLINE FUSE BE CHECKED FIRST BEFORE CONDEMNING THE CONTROL.
DAVID, THE GLASS TOP ELEMENTS ARE CONTROLLED BY THE SURFACE SWITCH FOR REGULATING TEMPS. THE SWITCH WILL TURN THE ELEMENT ON AND OFF TO REGULATE TEMP. I WOULD SUSPECT THE SURFACE SWITCH(WHAT THE KNOB IS ATTACHED TO) AS THE DEFECTIVE COMPONENT. THERE IS A HIGH LIMIT SWITCH THAT IS PART OF THE ELEMENT. IF IT WAS BAD, THE HOT SURFACE INDICATOR LAMP WOULD BE LIT ALL THE TIME.
THE ELEMENT IS NOTHING MORE THAN A COIL OF WIRE THAT HEATS WHEN CURRENT IS PASSED THROUGH IT.
IF IT WAS BAD, IT WOULDN'T DO ANYTHING AT ALL.
SOURCE: KitchenAid KWVU265YBA
had same problem. microcomputer part # 4360092 and micro switch part # 4360362 needed to be replaced. cost 255.95 and 23.59 for parts respectively.
SOURCE: kitchen aide dishwasher KUD101IL control panel not working
1. Check plug outlet.
2. Check electrical box underneath the d/w where power cord connected to d/w (you have to take the kick panel off . The box located on right side). Sometime you can find burn wire there.
3. Check the thermal fuse on computer board. It is inside the control panel on right hand side. The fuse has 2 white plastic connector which sticks out, easy to find.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
SOURCE: can this be installed over an island?
it should if you have a place to hang it/ power for it
