20 Most Recent
Rangemaster Kitchen Hood Questions & Answers
A bulb blew in my tecnik cooker hood and neither
In case you are still looking for an answer. The same happened to me.
I found a 3-amp fuse which I changed, and now it's ok.
I removed the chimney casing and located the electrical connection into
the wall. You'll find a fuse unit within the switch which swings out.
Hope this helps.
Range master 50000 exhaust fan stopped working
Extremely likely the fan motor. get to it then , after removing fan blade,plug it in directly to a 110v outlet ,just for a second to see if it works well( don;t touch it while prefoming this test,only the plug), or jumper out the switch(with electric disconnected) momentairly to see if the fan runs after turning the electric back on.
I have a 4 year old RM5200 hood over my stove. The
Range hood motors, bathroom exhaust fan motors all share the same thing. They become coated with grime inside the shaft of the rmotor due to their exhaust feature of sucking dust and grime over the motor, which is open. The only solution is to get access to the motor and clean the fan blades and squirt a little WD-40 down the shaft as that is where the noise comes from. The dirt and grime build up on the motor shaft, and eventually starts rubbing the bushing where the shaft rest and makes a noise. Yo must remove this from the shaft and allow a little play, and lubrication which the WD-40 will supply.
My rangemaster cooker hoos has
The same happened to me. I found a 3-amp fuse which I changed, and now it's ok.
I removed the chimney casing and located the electrical connection into the wall. You'll find a fuse unit within the switch which swings out.
Hope this helps.
