Tip & How-To about Dishwashers
When running in wash mode dishwasher leaking on both sides of outer door.
Check these first before calling a repairman.
1.Check door seal for cracked or missing seal.
2.Check for blocked screens.
3.Check for loose connection from pump to upper sprayer.
4.Check for anything blocking float valve. Make sure mushroom float has free travel up and down.
5.Check pump by running the dishwasher a few minutes and then drain.
6.Check for blocked discharge hose using step 5 above.
7.Check lower sprayer arm for cracks or splitting seams.
Most things to consider are listed above. If yours is leaking from both sides and the dishwasher is new. My leak was caused by wave action. If the dishwasher does this then it will cause the water to break over the front edge of the dishwasher and leak water from both sides. My dishwasher lower sprayer arm water holes were partially blocked and were causing this wave action. Remove the lower sprayer arm and run water though the center part while tilting it on end and notice if the water exits all holes in the sprayer arm. Do this for both sides. If yours like mine are partially blocked then try blowing out with compressed air or using you mouth to blow each blocked holes then running water after each try. Reassemble the spray arm and without any dishes in unit run the unit in rise mode a few times. Make sure arm is properly attached. Another problem is to try different dishwasher soap if nothing here works. Excessive soap can also cause this type of problem.
