20 Most Recent Dyson DC04, 05 Upright Vac Post Motor Filter 10-2308-07 Questions & Answers
How do I take cylinder off
2/14/2015 5:40:50 PM • Dyson DC04, 05... • Answered on Feb 14, 2015
Dyson Animal V6 flashing blue and red?
two faults, mainly battery. A flashing blue light indicates that there is no power, please charge the battery. A flashing amber light indicates that there is no power or a temporary fault (e.g. too hot/cold). A flashing red light indicates that there is a fault, please call the Dyson Helpline.
Support and How to Guides for your Dyson V6™ Vacuum
3/19/2024 2:47:52 AM • Dyson Vacuums • Answered on Mar 19, 2024
2answers
Dyson DC41
12/31/2023 6:14:55 PM • Dyson Vacuums • Answered on Dec 31, 2023
Is the base of a Dyson AM05 the same as a Dyson AM09?
Question edited for clarity. No it is taller https://www.google.com/search?q=dyson+am05+vs+dyson+am09 ..
12/29/2023 5:30:50 AM • Dyson Vacuums • Answered on Dec 29, 2023
The bottom of the clear canister opens before I am ready...have to re-vacuum. Lock not working correctly. Seems secure when attaching & vacuuming...just falls open before I can remove it.
Check for dirt in tracks of closure mechanism, clean as nessary. Also, check worn mis-aligned, adjusted clasp.
8/17/2023 5:30:43 AM • Dyson Vacuums • Answered on Aug 17, 2023
How to fix the Dyson dc21 motorhead
6/22/2023 11:22:43 AM • Dyson Vacuums • Answered on Jun 22, 2023
Dyson airwrap hair styler turns off at some heat settings and red light is blinking
If your Dyson Airwrap hair styler is turning off at certain heat settings and the red light is blinking, it could indicate a potential issue with the device. Here are a few troubleshooting steps you can try: 1. Check the power supply: Ensure that the Airwrap is properly plugged into a functioning power outlet and that the power cable is securely connected to the device. 2. Reset the device: Unplug the Airwrap from the power source and wait for about 30 seconds. Then, plug it back in and try turning it on again. This reset may resolve any temporary issues. 3. Clean the filter: The Airwrap has a filter located near the base of the handle. Check if the filter is clogged with dust or debris. If so, gently clean it with a soft brush or by rinsing it under running water. Allow it to dry completely before reinserting it into the device. 4. Check for overheating: The red blinking light on the Airwrap can also indicate that the device has overheated. If this is the case, it may have an automatic shut-off feature to protect against damage. Allow the Airwrap to cool down for a while before using it again. Make sure the vents on the device are clear and not blocked by hair or other obstructions. 5. Contact Dyson support: If the issue persists after trying the above steps, it's recommended to contact Dyson customer support for further assistance. They can provide specific troubleshooting advice or arrange for repairs if necessary. Remember to refer to the user manual or Dyson's official support channels for the most accurate and up-to-date information regarding your specific model of the Dyson Airwrap hair styler.
6/21/2023 9:21:46 AM • Dyson Vacuums • Answered on Jun 21, 2023
My Dyson n AM09 keeps flashing red light and shows 42
The Dyson support site has choices of visible issues about led staying on, letters f, c, h showing, or many other options
https://www.dyson.com/support/journey/troubleshooting/61874-01/visible-issue-243255
6/12/2023 3:30:24 AM • Dyson Vacuums • Answered on Jun 12, 2023
I purchased a genuine Dyson bin replacement and when I try to shut the bin lid after I put the new one in it won't close.
Where did you order the 'Genuine Part' from. It sounds like a Genuine copy made in China like the brush that was sent to me. Genuine parts only come from Dyson direct. Mine came from Amazon. https://www.google.com/search?q=genuine+dyson+bin+replacement ..
3/14/2023 4:57:46 AM • Dyson Vacuums • Answered on Mar 14, 2023
Broken latch on Dyson dc77/up14
1/23/2023 11:43:52 PM • Dyson Vacuums • Answered on Jan 23, 2023
On my dyson 02-89666B. The power head keeps shutting off when I go to vacuum. When its not flat on the floor it works
If the vacuum cleaner's airways become blocked, the device will automatically shut off to prevent damage. Check for blockage at the power head. It probably runs when not flat because it can suck air past the blockage. If the vacuum's filter is full of debris, the vacuum may lose suction, causing the device to turn off automatically...which I doubt in your case. Be cautious removing the blockage for sharp objects. Best to you
1/23/2023 8:19:56 PM • Dyson Vacuums • Answered on Jan 23, 2023
2answers
How do I stop my Dyson vacuum from whistling?
fix the vacuum leak probably an incorrectly fitted canister , or seal ring missing
1/19/2023 4:37:31 AM • Dyson Vacuums • Answered on Jan 19, 2023
What size Torx screwdriver do I need to fix a Dyson V8
You ONLY need a T15 for these models DC01, DC02, DC03, DC04, DC05, DC07, DC08, DC14, DC19 and DC25. If you are going to be working on models such as the the DC24 and other later Ball machines like the DC15 and DC18, and newer machines like the DC39, DC40 and DC41, not to mention new Cinetic machines, you will also need a T10 with an anti-tamper end and also a T8 for some jobs. If you are planning to repair later models, get a T8, T10 T and the T15 T (The extra "T" denotes anti-tamper).
1/14/2023 8:03:19 AM • Dyson Vacuums • Answered on Jan 14, 2023
My dyson dc25 got over full and just stopped working. It turned on with half power but wouldn't sick anything up and now won't turn on at all. Please help.
Here are a few steps you can try to troubleshoot the problem:
  1. Check the filter: Make sure that the filter is clean and that there is no blockage in the filter.
  2. Check the bin: Make sure that the bin is empty and that there is no blockage in the bin.
  3. Check the brush bar: Make sure that the brush bar is not clogged with hair or debris.
  4. Check the hose: Make sure that the hose is not clogged or blocked.
  5. Check the motor: Make sure that the motor is working properly.
  6. Check the power supply: Make sure that the power supply is working properly and that the vacuum cleaner is properly plugged in.
  7. Consult the manual: Consult the manual for specific troubleshoot and service information for your Dyson DC25 vacuum cleaner model.
1/14/2023 1:12:07 AM • Dyson Vacuums • Answered on Jan 14, 2023
Dyson Ball Cleaner Head suction stops when head is attached; Multi Floor 2; UP19
If the suction on your Dyson Ball Cleaner Head stops when the head is attached, it could be due to a problem with the head itself or with the vacuum's hose and wand. Here are a few things you can try to troubleshoot the problem:
  1. Check the hose and wand for any blockages or kinks. Remove any blockages or straighten out any kinks to restore suction.
  2. Check the hose and wand for any visible damage, such as holes or cracks. If the hose or wand is damaged, it will need to be replaced.
  3. Check the connection points between the hose, wand, and cleaner head to make sure they are secure and not loose.
  4. Check the filters to make sure they are clean and not clogged. If the filters are dirty or clogged, they can reduce suction.
  5. If the problem persists after trying these troubleshooting steps, you may need to take the vacuum to a repair center for further diagnosis and repair.
I hope this information is helpful! Let me know if you have any other questions.
1/4/2023 1:02:35 PM • Dyson Vacuums • Answered on Jan 04, 2023
Dyson dc24 no suction from hose
If your Dyson DC24 vacuum has no suction from the hose, it could be due to a blockage or a problem with the hose itself. Here are a few things you can try to troubleshoot the problem:
  1. Check the hose for any blockages or kinks. Remove any blockages or straighten out any kinks to restore suction.
  2. Check the hose for any visible damage, such as holes or cracks. If the hose is damaged, it will need to be replaced.
  3. Check the hose connection points to make sure they are secure and not loose.
1/4/2023 12:59:43 PM • Dyson Vacuums • Answered on Jan 04, 2023
Can this Dyson 14 be fixed?
It will be a blockage somewhere in the base. Videos that should help.
1/3/2023 12:30:33 AM • Dyson Vacuums • Answered on Jan 03, 2023
Dyson DC04, 05 Upright Vac Post Motor Filter 10-2308-07 Logo
1 questions posted
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Dyson Vacuums
  • Dyson Vacuums
Most Popular Question
cylinder off
  • Vacuums
