20 Most Recent Riccar 1500 Simplicity S24 And S20 Electric Suction Hose Assembly Questions & Answers
The switch to my Riccar 1500p hose is broken for the 2nd time. I don't want to replace the entire hose again, where can i get the switch and leads?
Take the screws out to take the handle apart. Remove the switch and take it to your hardware or local vacuum to to get the correct replacement.
3/8/2014 1:06:12 PM • Riccar 1500... • Answered on Mar 08, 2014
My Riccar 1800 won't turn on all of a sudden.
Question edited for clarity and spelling of maker. Question moved from TX Watches category. Try the thermal reset again. When you are using the vacuum and then turn it off, the motor is hot and there is no cooling airflow. If the vacuum is close to cutting out through overheating that lack of air will trip it. If you have digital multimeter, you can check the thermal switch for continuity. https://www.google.com/search?q=Riccar+1800+won%27t+turn+on ..
1/9/2024 7:16:56 PM • Riccar Vacuums • Answered on Jan 09, 2024
Riccar 8850 Upright Vacuum Cleaner. I need a wiring diagram for it please?
Question edited for clarity and typo. There is no wiring diagram available https://www.google.com/search?q=riccar+8850+wiring+diagram There is a video though Or you could ask the maker?
Vacuum Cleaner Operating Instructions
Riccar http://media.riccar.com > 8000_Owners_Manual How to Replace the Agitator Belt. (Models 8750 8850 & 8800 only). Unplug the units power cord. Turn the unit over and remove the bottom plate as described in ... 13 pages ..
10/14/2023 12:42:34 AM • Riccar Vacuums • Answered on Oct 14, 2023
Riccar R-200 vacuum? Not working by the areas the has the foot pedal, maybe where the motor wires attach?
If your Riccar R-200 vacuum is not working in the areas where the foot pedal is located, it is possible that there may be an issue with the motor or the motor wires. Here are a few steps you can take to try and troubleshoot the issue:
  1. Check the power cord: Make sure that the power cord is securely plugged into the wall outlet and into the vacuum itself. If the cord is loose or damaged, it could be causing the issue.
  2. Check the foot pedal: The foot pedal is what activates the vacuum's motor, so it's possible that there could be an issue with it. Make sure that the pedal is not stuck or obstructed, and that it is moving freely.
  3. Check the motor wires: If the issue is not with the power cord or foot pedal, it's possible that there could be an issue with the motor or motor wires. To check this, you'll need to open up the vacuum and inspect the motor and wires for any visible damage or loose connections. Be sure to unplug the vacuum before attempting any repairs.
If you're not comfortable troubleshooting or repairing the vacuum yourself, it may be best to take it to a professional repair service or contact the manufacturer for assistance.
2/14/2023 5:28:10 AM • Riccar Vacuums • Answered on Feb 14, 2023
My Riccar brush will spin for a second and then stop spinning.
bad drive motor
7/16/2022 8:00:15 AM • Riccar Vacuums • Answered on Jul 16, 2022
How do you replace a vacuum hose on a Riccar upright Vacuum.
Riccar Tandem Air models have a hose that has releases to push to remove the hose. Most Vibrance & 8000 series and older series vacuums have the hose attached to a swivel on the back of the vacuum. The hose can be unscrewed from the swivel. To remove the swivel you need to remove the vacuum bag inside the dust compartment, you must compress the tabs holding the swivel to the body to be able to pull it out.
1/4/2022 5:12:56 PM • Riccar Vacuums • Answered on Jan 04, 2022
Our handheld Riccar Gem R-4 stopped working. I looked and the bag was super clogged... oops. I cleaned it up but the machine won't turn on. Is there a fuse or breaker or ... is the motor shot?
Riccar uses an external thermal reset which is more reliable than most brands which use a thermal reset built into the motor. On your Riccar it will be on the back on the bottom left. It is a little tiny button that you will hear "click" when you push on it if it has been popped. If not it will not push in and you won't hear the click. The older models did not all have a reset button. If you have to keep pushing the reset it means that most likely you have a clog somewhere or the bag is full. It's rare but occasionally a thermal reset button may go bad and need replaced. https://www.google.com/search?q=Riccar+Gem+R-4+thermal+fuse ..
5/20/2021 4:53:43 PM • Riccar Vacuums • Answered on May 20, 2021
There is a screw inside my riccar Supralite vacuum how do I get it out?
Try tweezers!
5/31/2020 5:23:22 PM • Riccar Vacuums • Answered on May 31, 2020
Where is the reset button on riccar supraquick
Link below to company with some info and contact info https://www.riccar.com/customer-support One place it says if your vacuum has a thermal overload reset see owners manual if vacuum will not start. It also says make sure hose is not plugged and filter and bag are good. Manual below has a troubleshooting guide http://media.riccar.com/manuals/RSQ1_OM1706.pdf https://az589519.vo.msecnd.net/productdocuments/Riccar_RSQ1_supraquick.pdf
4/26/2020 6:39:56 PM • Riccar Vacuums • Answered on Apr 26, 2020
Power head on riccar canister vacuum doesn't turn onn
Either the cord is bad or the reset button has tripped. It could also be a bad hose or switch. Canisters are harder to diagnose because the electricity for the power nozzle runs from the canister to the power nozzle.
10/29/2019 9:25:35 AM • Riccar Vacuums • Answered on Oct 29, 2019
How do you get a broken wheel off a Riccar canister vacuum model moon 2 to replace it with a new one
I usually just break them off. The new one will literally pop on. Don't forget to take of the hubcap and put it on the new wheel.
10/29/2019 9:23:10 AM • Riccar Vacuums • Answered on Oct 29, 2019
I have a Riccar Brilliance. When I turn the vacuum on, the bag pushes so hard from the inside it starts to push through the left side...
I can’t really help with the bag issue because I’ve never heard of that before. But my guess is that the bag isn’t breathing properly or is overly full. If the vacuum sounds louder it’s possibly because the fan is off balance and/or the brush could be bad. To test this turn both switches on and listen is the vacuum sounds normal then we know it’s not the bypass motor. If however you put the handle back and the vacuum is loud it’s probably the fan in the direct air motor. You can also take the brush out and do the same test to see if the loud noise is coming from the brush. If you take the brush out and run both motors and they sound fine, you know the problem is in the brush. Hopefully that helps.
10/29/2019 9:00:16 AM • Riccar Vacuums • Answered on Oct 29, 2019
Riccar 500 vacuum will not start. hoses are not clogged, bag is in corectly, do not see any lights on, tried reset button still nothing. will not start.
The 500 model is pretty old. It could be a bad cord, switch or a loose wire,
7/14/2019 8:07:48 PM • Riccar Vacuums • Answered on Jul 14, 2019
I need to change the back wheel on my riccar supra lite
Slide a small screwdriver beside the wheel and rotate it to push up on the axle holding the wheel in place
10/23/2018 4:39:03 AM • Riccar Vacuums • Answered on Oct 23, 2018
The height adjustment on a 8955 riccar machine isnt self adjusthing.
Your 8955 could be up to 17 or 18 years old. If yours is old or has been heavily used it may have a wiring short somewhere. The screw holding the handle in to the body of the vacuum might be loose which can cause the handle to not full engage the switch. Try wiggling the handle back and forth to see if it causes the power to turn on and off. Tighten the screw holding the handle in. If the nozzle housing is restricted from pivoting freely by wear or dirt or debris the nozzle may not go all the way down when the handle is reclined back into the vacuuming position. Inspect the pivot area closely.
10/23/2018 4:07:52 AM • Riccar Vacuums • Answered on Oct 23, 2018
Riccar 1500 Simplicity S24 And S20 Electric Suction Hose Assembly Logo
2 questions posted
Top Riccar Vacuums Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Riccar Vacuums
  • Riccar Vacuums
Most Popular Question
switch riccar 1500p hose broken 2nd
  • Vacuums
