20 Most Recent Riccar 3623210300 RC 1700, 1800 Full Size Canister Electric Suction Hose Questions & Answers
You need to contact your local Riccar dealer. They are not available except from Riccar dealers.
www.riccar.com
Sorry.
Riccar... | Answered on May 31, 2014
Reset button on the bottom back of the machine.
Riccar... | Answered on Feb 16, 2014
Link below to company with some info and contact info
https://www.riccar.com/customer-support
One place it says if your vacuum has a thermal overload reset see owners manual if vacuum will not start. It also says make sure hose is not plugged and filter and bag are good.
Manual below has a troubleshooting guide
http://media.riccar.com/manuals/RSQ1_OM1706.pdf
https://az589519.vo.msecnd.net/productdocuments/Riccar_RSQ1_supraquick.pdf
Riccar Vacuums | Answered on Apr 26, 2020
Either the cord is bad or the reset button has tripped. It could also be a bad hose or switch. Canisters are harder to diagnose because the electricity for the power nozzle runs from the canister to the power nozzle.
Riccar Vacuums | Answered on Oct 29, 2019
I usually just break them off. The new one will literally pop on. Don't forget to take of the hubcap and put it on the new wheel.
I can’t really help with the bag issue because I’ve never heard of that before. But my guess is that the bag isn’t breathing properly or is overly full. If the vacuum sounds louder it’s possibly because the fan is off balance and/or the brush could be bad. To test this turn both switches on and listen is the vacuum sounds normal then we know it’s not the bypass motor. If however you put the handle back and the vacuum is loud it’s probably the fan in the direct air motor. You can also take the brush out and do the same test to see if the loud noise is coming from the brush. If you take the brush out and run both motors and they sound fine, you know the problem is in the brush. Hopefully that helps.
Slide a small screwdriver beside the wheel and rotate it to push up on the axle holding the wheel in place
Riccar Vacuums | Answered on Oct 23, 2018
Your 8955 could be up to 17 or 18 years old. If yours is old or has been heavily used it may have a wiring short somewhere. The screw holding the handle in to the body of the vacuum might be loose which can cause the handle to not full engage the switch. Try wiggling the handle back and forth to see if it causes the power to turn on and off. Tighten the screw holding the handle in.
If the nozzle housing is restricted from pivoting freely by wear or dirt or debris the nozzle may not go all the way down when the handle is reclined back into the vacuuming position. Inspect the pivot area closely.
you will need to get the whole base plate look on ebay
Riccar Vacuums | Answered on Sep 06, 2018
Start by checking the suction opening by the brushroll. Then remove the screws and take the nozzle cover off. Remove the cover to be able to inspect the impeller for clogs or debris. Pull the motor if necessary to gain access to the lower end of the suction tube/handle.
Riccar Vacuums | Answered on Sep 04, 2018
Your 8650 is likely about 30 years old. It may not have a reset switch. If it won't run it may need a new cord or switch. If it's in good shape it may be worth having it looked at by your local Riccar dealer.
Riccar Vacuums | Answered on Aug 05, 2018
Riccar 3623210300 RC 1700, 1800 Full Size Canister Electric Suction Hose Logo
4 questions posted
Top Riccar Vacuums Experts
brian kossman
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Riccar Vacuums
  • Riccar Vacuums
Most Popular Question
size replacement belt riccar 1700 vacuum
  • Vacuums
