20 Most Recent
Logitech Harmony 1000 Advanced Universal Remote with 3.5" Color LCD Touch Screen Questions & Answers
After a power outage, everything
Since the Harmony remote has no way of being affected by a power outage, I would say that this is more an issue with your receiver itself. There was probably a power surge, and the IR receiver may have been damaged. I would try the original remote, or call the manufacturer to see if there is any way to reset the receiver.
How do I get my wireless Logitech PS2 controller to connect to the receiver
Observe these instructions to connect your wireless Logitech PS2 controller to the receiver :-
- Verify that the PlayStation 2 console is connected to the receiver.
- Switch on the PlayStation 2.
- Replace the controller's batteries.
- For roughly 2 seconds, press and hold the receiver's sync button.
- Press and hold the controller's X button for 5 seconds.
- To verify a connection to the receiver, the controller LED should flash rapidly.
Try the following if the controller won't connect :-
- Double-check the placement of the batteries.
- Experiment with various batteries.
- Bring the controller up to eye level with the receiver. Try rebooting your PlayStation 2.
Try getting help from Logitech customer service if you're still having issues attaching the controller .
Here are some extra pointers :-
- Verify that no other controller is currently using the receiver.
- Verify that no other wireless devices are present that could interfere with the connection.
- You might need to utilise an adaptor to connect the receiver if you're using a PS2 Slim.
8/21/2023 5:11:27 PM •
Logitech...
Answered
on Aug 21, 2023
Need logitech z340 control pod or compatible controller even if not logitech brand
The Logitech Z-340 control pod or a compatible controller can be found in a few different places. Here are a few options:
- Logitech website: You can check the Logitech website to see if they still carry the control pod or compatible controller for the Z-340.
- Online retailers: You can check online retailers such as Amazon, eBay, and Best Buy to see if they have the control pod or compatible controller in stock.
- Specialized Electronic retailers: Some specialized electronic retailers like B&H, Newegg, and Fry's may have the control pod or compatible controller.
- Local electronics stores: You can check local electronics stores in your area to see if they have the control pod or compatible controller in stock.
- Second-hand marketplaces: You can also try checking second-hand marketplaces like Craigslist, Facebook Marketplace, and OfferUp to see if someone is selling a used control pod or compatible controller.
It's important to note that, if you decide to go for a non-Logitech controller, you should make sure it's compatible with your Logitech Z-340. And it's best to check the compatibility before buying the controller.
1/23/2023 10:25:33 AM •
Logitech...
Answered
on Jan 23, 2023
Have a logitech 610 remote stuck in safe mode. Tried holding #2 and changing batties with new batteries but still stuck in safe mode
I'm sorry to hear that your Logitech 610 remote is stuck in safe mode. Here are a few steps you can try to try to resolve the issue:
1. Make sure you are using new, high-quality batteries.
2. Try resetting the remote by removing the batteries, pressing all of the buttons, and then reinserting the batteries.
3. If the issue persists, try connecting the remote to the Logitech Harmony software on your computer using the supplied USB cable. This will allow you to access more advanced troubleshooting options.
I hope this helps! Let me know if you have any other questions or if there is anything else I can do to assist you.
1/2/2023 9:12:04 PM •
Logitech...
Answered
on Jan 02, 2023
Hello Carla here. So I purchased on eBay months ago a Logitech harmony 1000 universal remote but it did not come with any manuals or cords on how to program and set it up. Can u help?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
{View the site in web view by Mobile or a desktop to see the search box. Mobile view has no search box.}...
7/5/2019 8:39:02 AM •
Logitech...
Answered
on Jul 05, 2019
