20 Most Recent
iLive itb382b 37 hd wireless bluetoothr soundbar Questions & Answers
Can I use only 1 speaker ilive ISBW2113B speaker
Yes, you can use only one iLive ISBW2113B speaker. The iLive ISBW2113B is a Bluetooth speaker that can be used individually or paired with another speaker for stereo sound. If you prefer to use only one speaker, you can connect it to your audio source via Bluetooth or using a wired connection, depending on the available options on the speaker. Keep in mind that using only one speaker will result in mono sound instead of stereo sound. However, the single speaker will still be functional and able to play audio on its own.
Can I use only 1 of my ilive ISBW2113B SPEAKERS
Yes, you can use only one of your iLive ISBW2113B speakers. The iLive ISBW2113B is a Bluetooth speaker that can be used individually or paired with another speaker for stereo sound. If you prefer to use only one speaker, you can connect it to your audio source via Bluetooth or using a wired connection, depending on the available options on the speaker. Keep in mind that using only one speaker may result in mono sound instead of stereo sound.
My speaker is static no sound
Pull battery or power cord for 1 minute. Connect and then try connecting to you source again. Bluetooth issue or connecting with 3.5mm cable?? .
