Question about iLive Audio Players & Recorders
My ilive model no ihb603bv1240-02 when I insert cd it displays no in the track display window and will not allow the CD to play. this unit is 9 months old . please advise Pat
Posted by Ellen Cerutti on
5 Related Answers
Anonymous
  • 1512 Answers
SOURCE: DENON DN-C615 DISPLAYS "SERVO ON"
The owners manual references turning the servo on and off on page 8
mpro
.com/users/getdownload.asp?DownloadID=92" spwrap?>mpro.com/users/getdownload.asp?DownloadID=92">http://www.d-mpro.com/users/getdownload.asp?DownloadID=92
Good luck... Happy to help you further if things get complicated. A "FixYa" rating for this would help my profile. Thanks
Posted on Feb 12, 2008
Anonymous
  • 199 Answers
SOURCE: CD NOT WORKING
Ok guys thius it how it works.
Blaupunkt supply a repair kit for this unit, this basically is a fix. but only works for 8 out of 10units.
its a pain to fit too.
you have to replace the 3 spindle guides and arms. the part number is : 8619001490 there a reall complicated thing to fit.
i am looking to get a install guide sorted. and will soon be selling the kits on my website
www.carradiospares.co.uk
Regards
Mark
Blue ICE
Posted on Feb 24, 2008
Anonymous
  • 518 Answers
SOURCE: faulty goodmans 1104s dab player
In the lid should be a mgnetic plate that holds the disc to the motor spindle (much like slight pressure would). Inspect it to make sure it's free moving and seating all the way when the lid is closed. I had one unit where the spindle on the motor shaft had slid down slightly causing the magnetic plate to not seat down all the way. Also, if the magnetic plate is removable, try placing it on the disc with the lid open and bypassed and see what happens.
Hope that helps...
Geno
Posted on Mar 06, 2008
Anonymous
SOURCE: Error Message AO
I had the same issue, my battery was died due to headlight was ON and later player was showing AO. I am going to reset the unit and see if it will solve my problem.
Posted on Aug 24, 2008
jason
  • 905 Answers
SOURCE: When i insert a cd , display says 'NO CD' Model SL-HD350
it will need a manual cleaning of the laser lens
Posted on Dec 10, 2008
2answers
Ok the manual didn't tell me much I just need to find out how to work the CD player on a sylvania scr4986. Can someone help me. I'd really appreciate it.
Basic CD Operation:
1. Power the unit ON if STANDBY mode by pressing the STANDBY ON/OFF(#3).The default
mode is RADIO,so press the FUNCTION button(#8) to switch to the CD mode.
2. Open the CD door by pressing the OPEN/CLOSE door release button(#9).Inset a CD with the
label facing upwards and close the door.
3. The unit will read the disc and display the total number of tracks found on the disc on the
display
4. To begin playback press the PLAY/PAUSE/BAND button(#1).The first brack on the disc will
play.
5. To pause playback press the PLAY/PAUSE/BAND button(#1) once more.Pressing again resumes playback.
6. Press the STOP button(#2) to stop playback.
7. Use the AL 1/VOL- or AL 2/VOL+ buttons(13,14) to adjust the volume level.
Advanced CD operation
1. Press the FWD/TUN+ button to skip to the next track.Press and hold to fast forward the
current track.Release the button to resume normal playback.
2. Press the REV/TUN- button to skip to the previous track.Press and hold to fast rewind the
Random playback
1. Press and hold the SLEEP/RDM button(#15) either during playback or in STOP mode for 2
seconds and then release.You will see the letters RDM appear on the display to indicate the
RANDOM mode in active.
2. If you enable the RANDOM function in STOP mode,press the PLAY/PAUSE/BAND button
to begin playback.If you enable the function during playback the next track will begin the
random order
3. To cancel the RANDOM playback mode,press and hold the SLEEP/RDM button(#15) for 2
seconds and release again.The letters RDM will disappear from the display to indicate the
function has been cancelled.
Repeat function
1. Before or during playback press the REPEAT/PROG button(#6) to repeat a single track
indefinitely.You will see REP appear on the display when active.
2. To repeat all tracks on the disc,press the REPEAT/PROG button(#6) twice(or once more if
you have already activated the repeat once function).You will see REP on the display blinking
to indicate the repeat ALL function is active
3. To cancel any repeat modes,press the REPEAT/PROG button(#6) once more(if in repeat all
mode or twice if in repeat once mode).The letters REP will disappear from the display.
CD program playback.
NOTE:You can only program a playback sequence while the disc is in STOP mode.
1. Press and hold the REPEAT/PROG button(#6).You will see P01 appear on the display to
indicate the program function has been initiated.
2. Use the FWD/TUN+&REV/TUN- buttons to select the track you want to play in slot No 1.
3. Press the REPEAT/PROG(#6) to store the selected track in slot 1.The display will now
display P02 to indicate your selecting the track for slot 2.
4. Repeat steps 2 to 3 for every track you wish to program up to a maximum of 20 tracks. If you
try to program more than 20 tracks the display will revert back to P01 and will overwrite the
first slot again.
5. Press the PLAY/PAUSE/BAND button(#1) to begin the programmed sequence playback.
6. Should you wish to cancel the programming you can press the STOP button to resume normal
function.
1helpful
To Determine CD recording problem: Track1 records and plays back O.K. Upon completing track2, display window flashes continously "Now PMA" (Updating disc contents) NO playback or sound on track 2.
It is possible that until you finalize the disc, the only track that will play is the first one. Unfortunately, once you finalize the disc, you cannot record additional tracks to it. You can verify this by finalizing after recording the second track and seeing if they then both play. If that works, you can safely burn additional discs with confidence that they are burning correctly even if you cannot play each back after burning and must wait until finalization to test full burn.
1helpful
Denon CD deck
This unit needs a service visit. It may be a common problem with that model but to me it sound like a power supply issue as when you play a disc more power is used to rotate motors and move the sled. This is indicating to you that it is in a weakened condition and will soon fail more significantly. The problem may be as little as a solder joint or a defective Filter capacitor which is common in some models of equipment.
8helpful
Which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
"NO DISC" reading
Try this CD realignment process built into the Sharp XL HP505: Have unit off.
Hol down the square (stop) button and the X-BASS button while pressing the ON button. This starts the CD TEST. press play, the memory, then memory, memory, memory, adjustment lights will come on the screen. FOF, TOF, TBAL, TGAN, FGAN, RFLS. press cd1 - track 4, press cd2 - track 9, press cd3 - track 15. Press square (Stop).
If all the cd trays are full, then will light up . This worked for me.
1helpful
Need user manual
I have the CDR-200 and did not have the manual either. However, I did discover the same problem and found the solution. There is a "confirm" button on the front of the unit under the display area. After you press the record button "Record" will begin to flash in the display area and then you press "Confirm". It should start recording. Note however the following:
BURNING FROM EXTERNAL CASSETTE OR PHONO
Before starting this procedure make sure you have an AUDIO recording CD in the RECORDER tray of the CDR-200. A regular CD-R type of disc for computers is not going to work and may cause an annoying message on the display which does not go away until you put the right type of recording CD in the unit. It must be either an AUDIO CD-R or an AUDIO CD/RW.
1. When copying from an external cassette deck, you should set the source (press source button) until the setting is "Analog".
2. The "Dual" button should not be in effect. In the lower right portion of the screen you should only see a small number "1" with a circle around it. This indicates the CDs currently being used by the burner. In "dual" mode you can copy from the Playback CD of the CDR-200 to the Recorder CD. In dual mode you see "1" and "2" with circles around them. The active CD tray will flash on the display.
3. When copying from an external cassette unit, you use the "Record" button to start the recording. At the end of the cassette track you MUST press the STOP button by the CD Recorder tray. After you press STOP the unit will say "Update" which indicates it is closing out the track on the CD-R. You can continue to write tracks by pressing RECORD again, then CONFIRM when the tape is positioned at the right PLAYBACK track. It is usually helpful to have a few seconds of blank tape at the start of the PLAYBACK track before pressing RECORD. Press play on the cassette deck, then RECORD followed by CONFIRM on the CD burner.
4. When the track has finished burning you must press STOP to close the track on the CD-R. After you press STOP, the unit will display "Update" to indicate it is updating or closing the track. When the process completes, the unit will display the tracks it has written to the CD-R and will be ready for you to copy another track or FINALIZE the CD-R. When the unit is waiting after the STOP, you can change the cassette tape, reposition to a playback track and ready the playback tape for more recording. When the PLAYBACK tape is ready repeat STEP 3. Repeat steps 3 and 4 until you have about 14 or 15 tracks on the CD-R.
5. When you have finished recording about 14 or 15 tracks onto the CD-R, you will want to finalize the CD-R. Press the FINALIZE button, and then press the CONFIRM button. You will see the the unit start to display the progress of the finalize by advancing the level meters of the left and right channels in the display. When the unit is finished finalizing it will return to the number of tracks display for the CD-R. After finalizing the CD-R you can play it back to make sure the burn was successful. Be sure to wait for the tracks display before removing or playing the CD-R after the finalize is done. Removing before the finalize is done may damage the unit and may render the CD-R bad.
BURNING FROM THE PLAYBACK CD
1. Set the unit to "Dual" mode. As described above, you will see "1" and "2" with small circles in the lower right portion of the display.
2. Make sure the "Source" mode is set to "Analog" by repeatedly pressing the SOURCE button until it shows "Analog".
3. When copying from the PLAYBACK CD tray you will not use the RECORD button by the CD Burner tray. You will use the 'DUB" button just to the right of the display.
4. Put an audio CD in the PLAYBACK CD tray and press the skip track button ">>" until you arrive at the track you wish to record from. If the track you want to start at is track 1, then you don't need to skip tracks.
5. When positioned at the correct playback track, press the DUB button. The unit will show "CDR" and then "DUB" on the display. When it says "DUB" press the CONFIRM button. The unit will start recording. You can adjust the record level during the first few seconds to make sure you don't have the recording volume level set too high.
6. When the track is finished, you should see the unit indicate on the display "Update". This indicates it is closing the track and it should do this automatically. If it does not do this you may have to press STOP near the RECORDER Tray to force closing of the track. Usually the unit indicates "AUTO" in the display area and I believe that is what controls the automatic track numbering feature. I am not sure how the AUTO feature is turned on. I noticed on the CDR-200 it is on by default.
7. After the UPDATE is complete, the unit will display the number of tracks it has written to the CD-R. You can at this point change the PLAYBACK CD to another one or advance to another track for continued recording. When at the correct track simply go back to step 5 and continue.
8. When you are all done copying tracks from one or more CDs, and you wish to finalize the CD press FINALIZE and then press CONFIRM to start the finalize process. I noticed on the CDR-200 if you wait too long after recording a track the unit may start the finalize process automatically. This happened after at least 5 minutes. It is best to try and stay with the copy process to monitor what is happening. The finalize can also start if you have written to many tracks to the CD-R and it runs out of space. Typically, your safe if you burn about 14 to 15 tracks to a CD-R at a time. You might be able to fit more if the tracks are very short (2-3 minutes each).
One last note about the connections on the back of the unit. Read the labels of the connections on the back very carefully. The CDR-200 and probably the 201 have separate outputs for the PLAYBACK CD (CD) and BURNER CD (CDR). You will want to connect these to seperate inputs on your audio amplifier. Or you might also wish to merge them using adapters into one input on your audio amplifier. If you keep them separate you will need to change sources on the audio amplifier to hear each tray. For example, you might need to switch to "CD/TAPE" for the CD, and "AUX" for the CDR. It is probably easier to merge the two using audio adapters which can be readily obtained from RadioShack.
I hope this helps!
Kenwood RXD25 CD player intermitent??
Hi jenoss
Sounds like the unit has either a failing load belt to the cd drawer mechanism,not allowing the transport to fully load the cd. Give the unit a gentle tap just after the drawer closes and see if it resolves the problem.
OR a faulty spindle motor, you will have to take the lid off and after pressing play, give the disc a gentle "kickstart". If it then begins to run, then the motor is the problem.
If you find it is neither of these, get back to me here and I we shall go further
regards
Graeme
Ok I had the kenwood KDC-MP235 installed and...
The front aux input is only capable of accepting audio signals and definitely won't display any track tags.
If you have an iPod, I think with the KCA-iP500 adapter it will display song info on the front as well as allow control from the Kenwood's controls.
As far as the song info on a CD - it should display if you've got a CD with CDTEXT info on it, or if you're playing an MP3/WMA CD. Most regular audio CDs won't be able to display song info.
2answers
Playing cd's
You can find a user's manual here: http://www.ilive.net/action.php?name=200348996_UserManual-IBCD3816DT.pdf In case that link won't work, go here and select your model number: http://www.ilive.net/download.php
Top iLive Audio Players & Recorders Experts
ruggeg
 Grubhead
Grubhead
ray gallant
Are you an iLive Audio Player and Recorder Expert? Answer questions, earn points and help others
