20 Most Recent Samsung 900x Ultraportable Laptop Ultrabook Questions & Answers
How do I move programs from samsun 990x with a dead battery and broken power port?
Remove drive, read it with a USB to hard drive lead from Ebay. Read with new pc then run Belarc Advisor to get all the intalation codes
2/28/2015 1:05:47 AM • Samsung 900x... • Answered on Feb 28, 2015
How can I transfer programs to new computer from samsun 900x with a broken power port and a dead battery? S
OK, remove the hard drive, buy a hard drive to USB lead on ebay. Plug into a new computer run Belarc advisor http://www.belarc.com/free_download.html, this will read the whole computer and your hard drive and give the serial and codes. Once you have this you can re install the programs with the correct password and serial numbers
2/28/2015 12:54:39 AM • Samsung 900x... • Answered on Feb 28, 2015
My samsung 900x has not been used for 12 weeks and now will not turn on at all. Is there a procedure to bring it back to life ?
i know it's a silly question, but just to cover all bases, is the laptop plugged in to an outlet? sometimes the connections come loose on the "brick" (the square block on laptop power cables). try disconnecting/reconnecting that. do you see a light when you plug it in?
9/30/2014 10:21:55 PM • Samsung 900x... • Answered on Sep 30, 2014
I need the mac number of my samsung NP-900X3A
hello, assumed you are running a windows operating system on it (u didn't told here) then : press start button -> start typing cmd -> wait few seconds till your system found cmd, run it -> type into cmd : <ipconfig /all> (without <>, remark the space before slash) and press enter. the output now will list u all network adapters, including their mac-addresses. regards nayss
5/21/2014 6:35:10 AM • Samsung 900x... • Answered on May 21, 2014
Samsung ultrabook restarts
how to start wndows8 in safe mode with samsung ultrabook 900x
4/30/2014 6:50:57 PM • Samsung 900x... • Answered on Apr 30, 2014
I lost my laptop and need to know its mac number.
You can try finding the box if you have or alternatly you can check with the support department of you machines`s manufacturer if they have its mac number associated with it.
10/14/2013 2:03:12 PM • Samsung 900x... • Answered on Oct 14, 2013
Get this message upon boot up of samsung
Sounds like u got a virus. My suggestion is don't open up any mail or any sites that your not sure of.
10/13/2013 3:13:39 PM • Samsung 900x... • Answered on Oct 13, 2013
I need to reset the samsung 900x bios password
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu Please select an option: Safe Mode Safe Mode with Networking Safe Mode with Command Prompt Enable Boot Logging Enable VGA mode Last Known Good Configuration (your most recent settings that worked) Directory Services Restore Mode (Windows domain controllers only) Debugging Mode Start Windows Normally Reboot Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. select safe mode with command prompt Then type at the C:\> prompt: type DEBUG and hit Enter. You'll see a dash (-) at the DEBUG prompt. Now type: o 70 2e which will show as -o 70 2e at the DEBUG prompt. Hit Enter. Then type: o 71 ff and hit Enter. Finally type: Quit and hit Enter one last time to quit DEBUG back to the C:\> prompt. Now you're ready to reboot your PC, and press the appropriate key or key combo (look it up in your motherboard manual if you don't know it) to access your BIOS Setup. Youll notice the password is gone. If this fails try typing At command prompt type debug you will get a - prompt where you can type the following (<enter> means press enter, not type enter*) A <ENTER> MOV AX,0 <ENTER> MOV AX,CX <ENTER> OUT 70,AL <ENTER> MOV AX,0 <ENTER> OUT 71,AL <ENTER> INC CX <ENTER> CMP CX,100 <ENTER> JB 103 <ENTER> INT 20 <ENTER> <ENTER> just hit enter on this line G <ENTER> Q <ENTER> Basic BIOS password - works 9.9 times out of ten If this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password http://www.tech-faq.com/reset-bios-password.html At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410 http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
2/11/2013 6:49:11 AM • Samsung 900x... • Answered on Feb 11, 2013
How do I find the instruction manual with codes for my Samsung 32" curved screen monitor ?
Manufacturer's Website: Go to the manufacturer's website (visit the official Samsung website in this case). Click on the support section, search your monitor model by product name or model number, and download your monitor model for the user manual. User manuals usually list codes and other relevant information. User Manuals Online: Many people post user manuals online for all types of electronic devices and peripherals. You can search for your monitor and look for the user manual at sites such as ManualsLib, ManualsOnline, or Retrevo. Most of these sites will catalog user manuals for a wide variety of devices posted online by users and are normally free to access. Physical User Manual: If you still have the original box or packaging with your monitor, there might be a copy of the user's manual in that box or enclosed. It might be in an actual printed booklet or perhaps just some links to online resources. Check under a section entitled 'Remote Control Codes' or 'Setup Instructions'. Contact Samsung Support: If no luck finding it to download or to help you, there is contact support available, they should know where that information is, and be able to send it to you or refer you. With these, you should be able to find the user manual for your Samsung 32" curved screen display and enter those codes.
4/13/2024 10:32:28 AM • Samsung... • Answered on Apr 13, 2024
2answers
My samsung laptop systom is collapse
http://www.samsung.com/us/support/owners/product/NP530U4B-A01US
1/19/2024 4:43:52 PM • Samsung... • Answered on Jan 19, 2024
Can you help me with my Z3X Box? I can't use it with my computer!
Ask the makers for product support. This is basically a refined hack tool.
z3x-team
z3x-team https://z3x-team.com Samsung Tool Pro is a professional phone software servicing device. List of ... LG Activation. Z3X LG Activation - software product which enables your Z3X-Box ‎Samsung Tool Pro ACTIVATION · ‎Download · ‎Z3X-TEAM · ‎Z3x-team Q&A
12/31/2023 11:16:34 PM • Samsung... • Answered on Dec 31, 2023
Maquina de lavar Samsung wf90f5e5u4w
ENGLISH ONLY please. Samsung washing machine wf90f5e5u4w Hello good afternoon, I want to ask for help, I have a faulty module and I wanted to ask if you have the electronic diagram for the Samsung DC92-01240C washing machine, the machine model wf90f5e5u4w, I would really appreciate it if you could, thank you. greetings Antonio Paulo
Steam Wash, Washers Support ' Samsung Care US
Samsung https://www.samsung.com > washers > front-load > ste... Get the latest drivers, manuals, firmware, and software. Learn more. Request repair service. Arrange for a service visit at home, schedule a walk- ... https://www.google.com/search?q=Samsung+DC92-01240C+service+manual ..
12/4/2023 10:19:25 PM • Samsung... • Answered on Dec 04, 2023
Firmware for Samsung ht e5550 Blue Ray hometheater
Go to samsung.com for updates, if available.
11/28/2023 5:31:09 PM • Samsung... • Answered on Nov 28, 2023
Samsung GT C 3520 how do I connect to my home wifi?
The Samsung GT-C3520 flip phone does not connect to any wireless LAN. The phone only has GSM network connectivity. The manual for the Levant GT-C3520 is available here: https://www.samsung.com/levant/support/model.GT-C3520HAATHR/ . The current link to the manual is https://downloadcenter.samsung.com/content/UM/201202/20120227115742198/GT-C3520_UM_EU_Eng_Rev.1.0_110915_Screen.pdf . The specifications for the C3520 are available here: https://www.gsmarena.com/samsung_c3520-4218.php . I wish that I had better news for you. Cindy Wells
11/22/2023 12:30:04 AM • Samsung... • Answered on Nov 22, 2023
3answers
My notebook causes database problem
There may be a solution here, but I have never messed with SQL. https://dba.stackexchange.com/questions/88982/how-to-repair-database-consistency-errors
11/14/2023 7:01:28 AM • Samsung... • Answered on Nov 14, 2023
Samsung 900x Ultraportable Laptop Ultrabook Logo
22 questions posted
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Computers & Internet
Most Popular Question
transfer programs new computer from
  • Computers & Internet
