20 Most Recent
Thermador Professional Series PO301 Stainless Steel Single Oven Questions & Answers
I am having the same problem. Except when I turn on my broiler the E 6 number flashes over and over. I have called a zillion repairmen none of them will work on a Thermador
Thermador...
Answered
on Dec 28, 2018
We buy DeBruce Polish at debruce polish.com this stuff really works!!
Thermador...
Answered
on Jul 30, 2015
you have to remove the door and disassemble the whole thing.
I do them all the time.
Thermador...
Answered
on Feb 03, 2015
Hi someone lifted up on the door this ishowyou remove oven doors open the door about 1/3 then push down towards the floor it should go back into place, if not you may have to remove it clean the hinges then re-install it , I don't think anyone could have bent the hinges cause that would b very hard to do, but i have seen it done before , get back to me Frank
Thermador...
Answered
on Dec 13, 2011
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Thermador...
Answered
on Apr 02, 2011
Check your gas connection first. Check if the ignition is actually sparking.
Thermador...
Answered
on Jan 04, 2010
sometimes there is an internal fuse...
Thermador...
Answered
on Sep 28, 2009
Normally you force the hinges open and there will be a small hole to stick a nail in to keep them open. It is VERY hard to install the door if the hinges are trying to close it. You hold the hinges out with the nail while you install the door, then release the hinges to close by removing the nails.
Thermador...
Answered
on Aug 11, 2009
Your repairman might be right but I would have checked the main heating element first for this reason:
The self-clean cycle uses that same element as you need for the oven but is allowed to rise to a much higher temperature (~ 900-950 degrees) during the cleaning cycle and it may have self-destructed.
Since your problem started after the cleaning cycle, I would have checked the element for continuity first.
Thermador...
Answered
on Apr 20, 2009
Most likly a latch error.
Thermador...
Answered
on Aug 25, 2008
