20 Most Recent
Whirlpool ED5GHGXMQ Side by Side Refrigerator Questions & Answers
Loud humming noise
Have you had the noise before or did it just start?
Try to isolate where the noise is coming from. From under the fridge? On the back wall of the freezer side? If those two, could possibly be one of the fans.
12/11/2013 8:06:13 PM •
Whirlpool...
Answered
on Dec 11, 2013
Water is leaking on the
This can be due to overflow from the defrosted water tank. You need to move the fridge forward and remove the tank which is at the rear bottom of the fridge.
Now drain off the water and put back the tank into the slot.
Set the thermostat to NORMAL , check if there is leak on the gaskets or the drain pipe from the evaporator when the defrost timer works.
If the tubing is damaged then replace.
8/11/2011 6:23:01 AM •
Whirlpool...
Answered
on Aug 11, 2011
Compressor is not turning on
Yes, your overload relays have gone bad at the compressor. Install new overload kit and you will be fine.Hope this helped.
2/2/2010 3:39:23 AM •
Whirlpool...
Answered
on Feb 02, 2010
Icemaker does not fill with water
Try
using an hairdryer or defrosting the unit completely , this often get
rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to check the wiring to icemaker solenoid.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
5/22/2009 12:25:23 AM •
Whirlpool...
Answered
on May 22, 2009
Fridge not staying cold
Inside the fresh food compartment there is a defrost timer hidden behind the temp control panel. Sometimes there is a plastic plug over the hole that you need to put a flathead screwdriver in and slowly turn it clockwise. When compressor stops I want you to wait about 25 minutes to see if the refrigerator comes back on by itself without help. If it does I need you to listen inside the freezer compartment for sa sound of crackling or sizzling noise indicating defrost is taking place. Let me know, Sea Breeze
5/20/2009 5:35:44 AM •
Whirlpool...
Answered
on May 20, 2009
Compressor runs for 5sec.
your relay and overload on side of compressor is bad.you can replace with original parts or a 3-n-1 hard to start.
3/9/2009 2:41:22 PM •
Whirlpool...
Answered
on Mar 09, 2009
Will not dispense ice out door.
can oyu hear a "clicking" noise when you depress the ice actuator?? it needs to hit the microswitch behind the panel to switch on auger motor, possible bad switch or paddle not making contact with switch
5/20/2008 6:48:09 PM •
Whirlpool...
Answered
on May 20, 2008
Whirlpool wrv986fdem01 no lights
Check the control panel or display on the refrigerator for any error codes or indicators that might suggest a malfunction. Reset the control panel by unplugging the refrigerator for a few minutes and then plugging it back in.
4/3/2024 9:01:44 PM •
Whirlpool...
Answered
on Apr 03, 2024
Whirlpool refrigerator model WRB322DMBM0 1 with ice maker only. How do I find and change the ice maker filter
The Whirlpool WRB322DMBM01 refrigerator model typically does not have a dedicated water filter for the ice maker. Instead, it relies on an external water filtration system or an in-line water filter that may be installed in the water supply line connected to the refrigerator.
Here's how you can check for and change the water filter for your ice maker:
1. **Locate the Water Supply Line**: Trace the water supply line that connects to the back of your refrigerator. The water supply line is usually a flexible plastic or metal tube that runs from the water source (such as a water pipe or faucet) to the refrigerator.
2. **Check for an In-Line Water Filter**: Look along the length of the water supply line for any inline water filters. These filters may be attached to the water line using compression fittings or push-to-connect fittings. They are typically cylindrical or rectangular in shape.
3. **Inspect the Filter**: If you find an in-line water filter, inspect it to determine its type and condition. Some filters have a label indicating the brand and model number, while others may have a date or indicator showing when it was last replaced.
4. **Replace the Filter (if Necessary)**: If the water filter is due for replacement or is visibly dirty or clogged, follow the manufacturer's instructions for replacing it. This typically involves turning off the water supply, disconnecting the filter from the water line, and installing a new filter in its place.
5. **Flush the System**: After installing the new filter, flush the water system to remove any air or debris. Run water through the dispenser or activate the ice maker to purge the system of any trapped air or loose particles.
6. **Monitor Performance**: Monitor the performance of your ice maker and water dispenser to ensure that the new filter is functioning correctly. It may take a few cycles for the water system to fully adjust to the new filter.
If you cannot find an in-line water filter connected to your refrigerator's water supply line, it's possible that your refrigerator does not have a built-in water filtration system for the ice maker. In this case, you may need to consider installing an external water filtration system to improve the quality of your ice and water.
4/3/2024 12:33:05 AM •
Whirlpool...
Answered
on Apr 03, 2024
How to replace freezer light
Delete
To replace the LED light in your Whirlpool WRSSDHW08 freezer, follow these steps:
- Unplug the refrigerator to ensure safety.
- Remove all the items from the freezer to give yourself more room to work.
- Locate the light cover inside the freezer. The LED light should be underneath this cover.
- Carefully pry the light cover off using a flat-head screwdriver or your fingers. Be gentle to avoid damaging the cover.
- Once the light cover is removed, you should see the LED light module. It may be held in place by clips or plugs.
- Disconnect the power supply to the LED light. This may involve twisting or pulling the plug from its socket.
- Remove the old LED light module from the freezer.
- Purchase a replacement LED light module from the Whirlpool website or an appliance parts store. Make sure to get the correct part number for your specific refrigerator model.
- Install the new LED light module by connecting it to the power supply and placing it back into its slot in the freezer.
- Replace the light cover by snapping it back into place.
- Plug the refrigerator back in and test the new LED light.
If you have any trouble replacing the LED light or if you are unsure about any steps, consult the user manual for your Whirlpool refrigerator or contact a professional appliance repair technician for assistance.
3/29/2024 9:30:21 PM •
Whirlpool...
Answered
on Mar 29, 2024
