20 Most Recent
Acer AL1706b 17"LCD Monitor Questions & Answers
My Acer 1706 flat panel monitor went blank.
It seems that you have a failing backlight lamp or inverter board, these components are inside monitor, you should take it to an Acer service center, don't forget to check if you have a valid warranty, in this way you can save some money.
ViewSonic vg2230 back light keeps going off.
the inverter has gone out. You need to get a new one, but it might be cheaper to buy a new monitor than have it replaced.
If you are able to do it yourself look for it on ebay.
11/12/2017 9:58:16 PM •
Acer AL...
Answered
on Nov 12, 2017
No display
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
4/25/2014 1:41:55 AM •
Acer AL...
Answered
on Apr 25, 2014
