20 Most Recent Acer AL1715 (Black, Silver) 17" LCD Monitor Questions & Answers
0answers
Why does it have a blue tint?
It was possible of dead pixel, to check if there was a dead pixel go to http://jasonfarrell.com/misc/deadpixeltest.php or download dpt from http://dps.uk.com/software/dpt to test if there was really dead pixel on the monitor
1/29/2016 9:35:31 AM • Acer AL1715... • Answered on Jan 29, 2016
2answers
What is the price?
prices:
for ebay it is US $39.99
7/11/2015 12:11:29 PM • Acer AL1715... • Answered on Jul 11, 2015
Why does my Acer monitor display OSD LOCKOUT whenever I start up?
hold the power button for a few seconds it should say osd unlocked.... if that doesn't work unplug the monitor for a minute or so and plug it back in.. that should fix it
4/7/2015 12:49:14 PM • Acer AL1715... • Answered on Apr 07, 2015
WHAT DOES OSD LOCK OUT MEAN?
Hello it means that the on On Screen Display is locked...more below. Hope this helps What does OSD Locked mean
12/8/2014 6:15:39 PM • Acer AL1715... • Answered on Dec 08, 2014
3answers
Acer AL1715 17" LCD Monitor
Certain versions of the Acer AL1715 monitor had a problem with the VGA socket. Specifically, the plastic case around the socket was not wide enough. The plastic interfered with the plug and so the plug did not seat properly. I fixed several of these monitors by shaving off some of the plastic with a dremel mototool. A hand file would probably work as well. You have to remove the plastic back to do the job.
10/15/2014 3:09:02 AM • Acer AL1715... • Answered on Oct 15, 2014
2answers
Ghosting
I know exactly what your talking about. I've seen in many times. It' happens too in CRT monitors as well as LCD. It could ALTHOUGH be as simple as a bad cable catching interference. Most likely though, it sounds like a bad LCD driver board or video board. If you have warranty, call it in. Otherwise see if it lessens with adjustments of contrast and brightness up and down. This directly affect the driver board power and can improve it enough to be tolerable again.
10/9/2014 5:10:53 PM • Acer AL1715... • Answered on Oct 09, 2014
I have the audio cable running from the surface rt to the acer monitor and get no sound,what should i do
I would check the volume on your device to make sure it is at a medium level. Then adjust the volume on the monitor using the second and third buttons from the left on the front controls. If I remember right the monitor needs to be on for the speakers to have power. This link should help. Acer AL1715 User Manual
6/13/2014 4:35:40 PM • Acer AL1715... • Answered on Jun 13, 2014
0answers
No display
Be the first to answer 4/12/2014 4:45:34 AM • Acer AL1715... • Posted on Apr 12, 2014Be the first to answer
I HAVE RED DOTS ALL
Could be whats known as dead pixels, this is tested be showing up a black or white screen. Microsoft paint or word will do. If an area always has dots then dead pixel. However if it doesn't constantly remain a dot then, some-thing else. Dead pixels come about due to age.
A technician will be able to diagnose your problem by performing white screen test.
damnor01
8/31/2013 9:16:48 PM • Acer AL1715... • Answered on Aug 31, 2013
3answers
Red Vertical lines on 15" Acer LCD Monitor
I think this is most likely a monitor problem. Can you try a different monitor of computer to the monitor? That would help pinpoint the problem. Is it under warranty?
7/7/2013 10:38:21 AM • Acer AL1715... • Answered on Jul 07, 2013
I need drivers for windows 98
Hi and welcome to fixya you could go for the official website of Microsoft. there you can find what you are looking for
12/8/2012 4:46:25 PM • Acer AL1715... • Answered on Dec 08, 2012
0answers
I have a fixed image
Well, it certainly is related. This is OSD (On Screen Display) for adjustment, activated by those pushbuttons.
Did you try to completely unplug the power cable from the monitor for a minute and then reattaching it?
One of those pushbuttons may have got stuck in a depressed position, check if all of them click properly when pressed; sweet drinks spilled and dried off can make a button stick, and sometimes the plastic itself may develop enough friction for a button to stay in a depressed position.
If all the buttons work freely, the monitor may need professional servicing.
7/24/2011 7:38:23 AM • Acer AL1715... • Answered on Jul 24, 2011
WHERE IS THE OPTIION IN
LCD monitors do not have degaussing, it is not needed
6/9/2011 2:23:30 PM • Acer AL1715... • Answered on Jun 09, 2011
Screen comes on and then goes blank.i checked for
You need to check the DC voltages and DC filter caps.
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1715b/
Please read my guide first.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
3/9/2011 6:01:18 PM • Acer AL1715... • Answered on Mar 09, 2011
Windows logon screen flashes for 6 minutes
After the 6 minutes, what happens? Does Windows finally load? Does it power OFF?
Let's assume Windows eventually does load. The problem wouldn't be the monitor, instead look at your boot devices. You "could" have a USB Flash drive installed on your computer and that may affect the boot process. Try removing any external USB drives from your computer and try booting again. If it does load quicker, you have to check the internal configuration / setup screens on your computer. There is a boot sequence or boot order sequence that needs to be altered.
3/9/2011 2:29:27 PM • Acer AL1715... • Answered on Mar 09, 2011
I am unable to turn
If none of the button are working then it could mean that one of the buttons is stuck or there is an issue with the board on the monitor itself.
Unplug the monitor from power and the computer. Make sure none of the buttons are stuck down, plug only power back in to the monitor and see what it shows. Plug it back into the computer and check to see if the problem returns
3/7/2011 8:59:36 PM • Acer AL1715... • Answered on Mar 07, 2011
Acer AL1715 (Black, Silver) 17" LCD Monitor Logo
113 questions posted
Ekse
Steve Sweetleaf
Steve Sweetleaf
View Most Popular
AL Acer
  • AL Acer
Most Popular Question
fixed image
  • Computers & Internet
