20 Most Recent
Sharp (AN-XR10LP) Projector Lamp for XR10X Questions & Answers
I have a Sharp XR-10X-XL projector, i have
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
8/26/2016 4:10:53 AM •
Sharp...
Answered
on Aug 26, 2016
After replacing bulb, when the projector was
Please check the light tunnel and the reflector glass in the projector ,
it seems that the light tunnel or the reflector glass is failed
Have a nice day!
Jerry
Lampdeng Limited
8/26/2016 4:10:05 AM •
Sharp...
Answered
on Aug 26, 2016
NO POWER TO UNIT...
yes. it's warm up there. and it's suceptible to alot of dust and dirt. all of that will cause the projector to overheat frequently. also: if you've had to reset it that many times, it's wearing out, and you should replace the bimetal breaker (the little red button).
8/19/2009 6:45:47 PM •
Sharp...
Answered
on Aug 19, 2009
Lamp won't turn on.
I have a sharp xr10x ..........the problem lies in the bulb it needs a warmer temprature for the gas to expand in the bulb to fire and light up... hold a hair dryer up to the side of it fo a while and then fire it up still holding the haidryer up to it till it starts it may take a couple tries... ( this is a fix if your having a no buld startup problem and you know your bulb is still good) THIS IS THE FIX IF**** the lights will blink green for a while then one red and one green then will (shut off at both red) and not restart***
i had the same problem and thought id have to get a new bulb but this is the fix....
2/23/2009 5:26:55 AM •
Sharp...
Answered
on Feb 23, 2009
System lock of my projector sharp 50s ,so how to unlock?
- Check the Remote: Make sure you have the remote control for the projector.
- Press the Menu Button: On the remote, press the "Menu" button.
- Navigate to Security or System Lock: Use the arrow keys on the remote to navigate through the menu options. Look for a section related to "Security" or "System Lock."
- Enter the Unlock Code: If you previously set a system lock code, you will need to enter it using the remote control. If you haven't set a code before, try the default code (often 0000 or 1234).
- Disable System Lock: Once you've entered the correct code, navigate to the option to disable or unlock the system lock.
- Confirm: Follow the on-screen instructions to confirm your choice, and the system lock should be disabled.
Sharp EL-1197PIII printing nonsense after a jam.
Reset the calculator: Locate the reset button on the bottom or in the battery compartment and press it .
Clean the printer head: Use a soft, dry cloth to clean the printer head and ensure that there is no debris or paper stuck in the printer mechanism .
you are looking for resources to properly align the gears. I found a few resources that might be helpful:
Sharp EL-1197PIII Operation Manual: This manual provides detailed instructions on how to operate and maintain your calculator, including how to align the gears. You can download the manual from the following link:
SHARP EL-1197PIII OPERATION MANUAL Pdf Download ' ManualsLib.
Sharp EL-1197PIII User Manual: This manual also provides instructions on how to align the gears of your calculator. You can access the manual online from the following link:
Sharp EL-1197PIII User Manual online (mans.io).
Sharp EL1197PIII Heavy Duty Color Printing Calculator User Manual: This manual provides instructions on how to align the gears of your calculator. You can download the manual from the following link:
User Manual Sharp EL1197PIII Heavy Duty Color Printing Calc ' manualsFile.
My fridge won't stop beeping though door is closed
Posibllities to eliminate: 1) bad door seal 2) unbalanced fridge on floor 3) buildup of ice in fridge (defrost) 4) faulty door alarm.
Check temp of fridge. Adjust up or down depending on whether too hot or too cold. Check for blocked air flow or too many items in freezer. But if the exterior is much warmer than usual, you may be looking for a repairman. The main circuit board might be blown
Try a reset by unplugging it for 5 minutes, then plugging it back in. If a minor problem, this may stop the beeping.
