20 Most Recent Vtech i6772 Trio Cordless Phone Questions & Answers
0answers
Searching
Be the first to answer 12/23/2017 5:21:03 AM • Vtech i6772 Trio... • Posted on Dec 23, 2017Be the first to answer
0answers
Need to change lanuage on machine
well check if a button say language or search for it in the menu and actually wat language it is
6/29/2009 11:05:28 PM • Vtech i6772 Trio... • Answered on Jun 29, 2009
The answering machine messages are completely disthorted
Get the manual & check for the settings to clear teh message
www.vtechphones.com/vtechui/support/manual.cfm?manualID=21705 - 27k
3/19/2009 6:13:32 PM • Vtech i6772 Trio... • Answered on Mar 19, 2009
VT ip8100 - enter base id problem
24Ghz Vtech phones cant find base
12/21/2008 2:34:51 AM • Vtech i6772 Trio... • Answered on Dec 21, 2008
Vtech A5874 answering machine not working & letter A shows.
Somehow the answering machine was clicked off, but the announcement was on. Therefore I could not receive messages, but my recording was still on as if I was receiving incoming messages. I just played with the various on/off switches till it worked. For me, just plain luck.
10/1/2008 1:35:23 AM • Vtech i6772 Trio... • Answered on Oct 01, 2008
Answering machine does not take messages
answering machine does not record message but keeps showing an A on screen
7/28/2008 4:36:03 PM • Vtech i6772 Trio... • Answered on Jul 28, 2008
How to delete a phone number from directory on a vtech dect 6.0
In the link https://www.google.com/search?q=delete+a+phone+number+from+directory+on+a+vtech+dect+6.0 Did you realise you are advertising your email address to the 12 MILLION annual viewers of this site. ..
12/19/2023 4:29:33 AM • Vtech Lands... • Answered on Dec 19, 2023
Vtech cordless landline phone When I make a call to someone the other person can't hear me but I can hear them? Please help me in how to fix. Thank you
Google make model manual you have 'Mute' set on it. All questions need 'make model (what it is)' as first 3 words. ..
12/19/2023 4:27:21 AM • Vtech Lands... • Answered on Dec 19, 2023
I live in South Africa. Ordered a vtech 2 handset phones, DS6621-2 on Amazon & it came with 12 volt charger for main cradle. Can I get 6 volt charger with the right fitting and if so, how?
You are heading at this from the wrong end. The power to the device from the charger remains the same. If the device runs on 12 volts, it needs 12 volts. South Africa runs on 230 volts, so if you bought a 110 volts version, you buy an adapter that takes 230 mains voltage in, and delivers 12 volts DC to the phone. The phone won't run on 6 volts. 230V South Africa operates on a 230V supply voltage and 50Hz. ..
12/19/2023 4:25:51 AM • Vtech Lands... • Answered on Dec 19, 2023
Why does the letter A stay in my window of my Vtech answering machine
Google make model manual It likely means the Answering system is set or not set. https://www.google.com/search?q=letter+A+in+window+of+Vtech+answering+machine 'make model (what is is)' in all questions, first 3 words please. ..
12/19/2023 4:19:55 AM • Vtech Lands... • Answered on Dec 19, 2023
2answers
Vtech cs6649 shows incorrect date and time on caller id
i like this site
12/4/2023 11:27:02 PM • Vtech Lands... • Answered on Dec 04, 2023
Deleting pre recorded answer message on vtech fs6424a
Remove greeting from the voicemail
12/4/2023 3:50:13 PM • Vtech Lands... • Answered on Dec 04, 2023
VTech CS5249 phone. How do I unmute the ringer?
Page 29 and 59 of the manual refers. Page 23 Point 16 is probably the reason. The Ringer Volume is at Zero. https://cdn-web.vtp-media.com/products/CS/CS5249/CS5249-X_WEBCIB_V2_210710.pdf a neat trick is to press CTRL+F on your computer and type 'ringer' and press Enter. There are 47 mentions of it. ..
10/24/2023 11:47:28 PM • Vtech Lands... • Answered on Oct 24, 2023
One handset on Vtech CS6919-2 has a loud buzz. I bought one CS-6919 to replace but but I cannot register it?
i can,t find my imei # for my vtech cordless landline phone. model #is cs6919-2 & the s/n is uf 203447732 all i can on the is these two numbers.i need the imei# to get it turn back on.can you help me please,please.please get to me [email protected]
10/23/2023 3:45:14 PM • Vtech Lands... • Answered on Oct 23, 2023
I have a VTech 6929 Phone system. I have tried everything in the manual instructions, but I cannot set up my mail box. I had it previously, and somehow it is gone. Can you help?
Question edited for clarity.This phone system has two features.Answerphone system which records messages to the unit.andVoice Mail System which is an extended (often paid) service from your telephone provider.Sometimes a glitch at the Telcom will remove your Voice Mail. You will need to phone their customer service number and ask why they stopped the service you previously enjoyed? They will be able to put it back in place.Page 32 refershttps://cdn-media.vtechphones.com/products/CS/CS6929/CS6929-X_WEBCIB_V3_20160224.pdfRetrieve voicemail from telephone service Voicemail is a feature available from most telephone service providers. It may be included with your telephone service, or may be optional. Fees may apply. Retrieve voicemail When you received a voicemail, the handset displays New voicemail and . To retrieve, you typically dial an access number provided by your telephone service provider, and then enter a security code. Contact your telephone service provider for instructions on how to configure the voicemail settings and listen to messages. NOTE After you have listened to all new voicemail messages, the indicators on the handset turn off automatically. Set your voicemail number You can save your access number on each handset for easy access to your voicemail. After you saved the voicemail number, you can press and hold to retrieve voicemail. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Voicemail #, and then press SELECT. Use the dialing keys to enter the voicemail number (up to 30 digits). Press SELECT to save. You hear a confirmation tone. • 1. 2. 3. 4. 5. 33 Turn off the new voicemail indicators If you have retrieved your voicemail while away from home, and the handset still displays the new voicemail indicators, use this feature to turn off the indicators. NOTE This feature turns off the indicators only, it does not delete your voicemail messages. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Clr voicemail, and then press SELECT. You hear a confirmation tone...
10/21/2023 8:04:01 PM • Vtech Lands... • Answered on Oct 21, 2023
Date and time not correct when listing to voice mail
Possible battery is down. Refer to page 58 of manual CS6529-4B_UM_V5_20141120.pdf (vtechphones.com) for further details.
9/15/2023 1:43:33 PM • Vtech Lands... • Answered on Sep 15, 2023
Vtech i6772 Trio Cordless Phone Logo
19 questions posted
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Vtech Lands Phones
  • Vtech Lands Phones
Most Popular Question
need change lanuage machine
  • Lands Phones
