20 Most Recent Sony HVR-A1E HDV Digital Camcorder Questions & Answers
This video goes over the problem you are having.
Sony HVR-A1E HDV... | Answered on Aug 04, 2014
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and will require disassembling the camera and LCD assembly to remove and replace the flex cable. This can be done fairly inexpensively. However, it's not really a user serviceable problem and should be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
hi,
yes it has, go in camera settings
but if advise you, better not to use it because too much pixelizing with deep zooms (that's why it is desactivated from the beginig)
Sony HVR-A1E HDV... | Answered on May 18, 2014
dear ... there is an option in the menu .....
of hvr A1 TO KEEP THE VIEW finder.... ON..
write nw
ur camcorder is in auto mode ,wht happen in auto mode is ,view finder gets ON only when u turn the LCD pannel ...
so need nt worry change ur MENU option OF view finder from AUTO to ON,......
Sony HVR-A1E HDV... | Answered on Jul 13, 2012
no ,but you will have a dvd quality picture. HD means
the picture size format usely 16:9, HDMI its a Hd
multimedia interface its HD quality to...
hope that help you..
Sony HVR-A1E HDV... | Answered on Mar 25, 2012
I am one of the lead technicians at VideoOneRepair.com toll free 888 283 2228. We are a repair shop that specializes in only Sony and Canon Prosumer camcorders. The problem that you are experiencing with your Sony HVR-A1U camcorder is a common problem with this model camcorder. The ribbon cable that connects the LCD screen to the main part of the camcorder goes faulty and needs to be replaced. Sony also recommends that when this cable is replaced you must also replace a modified part to prevent this from happening again. The estimate to replace both of these parts is $360.19 parts and labor. This also includes cleaning and servicing. We also offer a 6 month guarantee on the entire camcorder, not just what it was sent in for. The estimate and the return shipping are free even if you do not have the camcorder repaired. Please feel free to call, email or post any questions you have and I would be happy to respond.
Sony HVR-A1E HDV... | Answered on Nov 28, 2011
I am one of the lead technicians at VideoOneRepair.com. We are a repair shop that specializes in only Sony and Canon Prosumer camcorders. The problem that you are experiencing with your Sony HVR-A1U camcorder is a common problem with this model camcorder. The ribbon cable that connects the LCD screen to the main part of the camcorder goes faulty and needs to be replaced. Sony also recommends that when this cable is replaced you must also replace a modified part to prevent this from happening again. The estimate to replace both of these parts is $360.19 parts and labor. This also includes cleaning and servicing. We also offer a 6 month guarantee on the entire camcorder, not just what it was sent in for. The estimate and the return shipping are free even if you do not have the camcorder repaired. Please feel free to call, email or post any questions you have and I would be happy to respond.
Sony HVR-A1E HDV... | Answered on Nov 17, 2011
The most likely cause for this is a zoom or focus lens out of place or impaired in some way. This will require disassembling the camera to remove the lens assembly and then disassembling the lens block to repair. This can be done fairly inexpensively but it's not really a user serviceable problem and should be repaired by a qualified service technician.
Sony HVR-A1E HDV... | Answered on Sep 23, 2011
Dear
your camers touch screen needs to get replaced by a service centre on an expert engineer.
Sony HVR-A1E HDV... | Answered on Jun 17, 2011
Dear
need not try any tips, as its the problem of mechanical deck, which is giving this problem it needs to get replaced, as the cable on the back of hvr-a1, mecha deck gets broken....
due tow hich the error starts coming...
get that replaced
Dirty heads may cause TimeCode breaks. Try a clean.
The fast start feature of this camera can also cause problems during recording.
Sony HVR-A1E HDV... | Answered on Feb 17, 2011
It sounds like you are using an aftermarket (non-sony) battery pack. The camcorder you are using probably requires the Genuine Sony 'Infolithium' Battery pack (usually in the box of the camera). If you are getting this message with the proper battery installed, i would contact SONY
Sony HVR-A1E HDV... | Answered on Jun 17, 2010
Camera gives Moisture error sign if it really have moisture condensation inside or its moisture sensor itself got defective.
if moisture is inside, blow hot air in camera mechanism for 5-6 minutes by hair dryer (not so closed with mechanism) and check / test.
If problem still exist it means moisture sensor is defective and i know its Sony high-end model camera and know how to fix it yet I would recommend to take camera to Sony Service center for proper repair.
Sony HVR-A1E HDV... | Answered on Dec 12, 2008
First and foremost shut down the device. Remove the battery if possible for 1 minute. Then restart/power up device. If still no luck or response. Go into the setting and look for the reset to default setting if there is no option for touch screen controls. Best of luck
Sony HVR Video... | Answered on Apr 20, 2014
Sony HVR-A1E HDV Digital Camcorder Logo
29 questions posted
Top Sony Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Larry Stiles
Larry Stiles
Al Rush
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
HVR Sony
  • HVR Sony
Most Popular Question
lcd camera faint doesn 39 t
  • Video Cameras
