20 Most Recent Sony HVR-HD1000U Camcorder Questions & Answers
hi,
the tape deck mechanism is faulty, the remedy is to change the mechanism. if you can repair it open take out the mechanism, remove the head, eject housing,and the sensors mechanism locking plate etc, then peel out the flexible cable from the mechanism, and change it.
Sony HVR-HD1000U... | Answered on Mar 02, 2016
hi,
the fault should be in side the cam, start test from the charger connecting socket, measure the power in the mother board, if any of the fusible resistor or the regulator SMD found faulty, must replace.
Sony HVR-HD1000U... | Answered on Mar 01, 2016
hi,
Your owners manual will show you on page 74 how to connect the iLink cable between the camera and computer. If you have lost the manual, it is downloadable for free.
Sony HVR-HD1000U... | Answered on Oct 17, 2013
hello, i think the tape tab is jammed if you will need help to: Disassembly,Repair, Maintenance or adjustments and more you can download the factory service manual from the below link:
http://goo.gl/ubSnD
Good Luck
Sony HVR-HD1000U... | Answered on May 16, 2013
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sony HVR-HD1000U... | Answered on Feb 02, 2011
Hello.
This problem is solved by replacing the cassette complet mechanism, part number A1437006A MD (N220) SUB ASSY (S) A
... the cause: the flex is broken.
you can buy it on this website: https://www.servicesplus.sel.sony.com/sony-part-number-A1437006A.aspx
Hollmann.
[email protected]
Sony HVR-HD1000U... | Answered on Dec 09, 2010
You will need a cleaning cassette- the same type that you record on, but with a cleaning tape in it instead of recording tape.
Sony HVR-HD1000U... | Answered on Nov 02, 2010
Buy it from :-
https://www.servicesplus.sel.sony.com/groupid503401.aspx
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sony HVR-HD1000U... | Answered on Sep 04, 2010
No Sony camera will work with Win 7 as yet (with USB cable) however Firewire cables do work okay?
Sony HVR-HD1000U... | Answered on Jun 26, 2010
First and foremost shut down the device. Remove the battery if possible for 1 minute. Then restart/power up device. If still no luck or response. Go into the setting and look for the reset to default setting if there is no option for touch screen controls. Best of luck
Sony HVR Video... | Answered on Apr 20, 2014
Sony HVR-HD1000U Camcorder Logo
32 questions posted
Top Sony Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Larry Stiles
Larry Stiles
Al Rush
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
HVR Sony
  • HVR Sony
Most Popular Question
sony hvr hd1000u
  • Video Cameras
