Here are the specs for your speaker.
Dual 4 Ohms Nom. Impedance
Fs: 40Hz, Qms:5.0, Qes: 0.90, Qts: 0.75, SPL: 84(dB), Vas: 5.204(Cuft)
That should help you design a good box.
The eight terminals are actually 4 with double slide ons for each. Each side has a + (positive)
and a - (negative) with 2 connectors at each connection point.
It is a dual voice coil thus 2 sets of inputs.
If you have a 4 ohm amplifier then you are ready to go with a left to one side's terminal and a right amp output going to the other. If you have 2 speakers this can get wild because you can run them in parallel
or series and reduce the impedance to 2 ohms if your amp is 2 ohm stable. If not-dont do it!
You will burn the amp up. See #58 on the right sidebar of this site. It will teach you how to get the most
from your setup. Bookmark the site. It has every kind of knowledge you need for audio or electricity.
Look for the DVC (dual voice coil) info.
"The image below shows the DVC speaker wired to both channels of a stereo amplifier. Each channel of the amplifier drives a 4 ohm load. " This looks like what you have to do.
http://www.bcae1.com/
