SOURCE: old rockford fosgate power 1001bd
The 1001BD will produce it's rated power (1000 watts RMS into 2 ohms).
SOURCE: rockford fosgate punch 700s gets very hot
Disconnect the speaker wires from speaker terminals on the amp and turn the amp on (turn the head unit on). Set the volume to zero on the head unit.
Does the amp get hot?
If it does, either the bias is set to high or the amp has other problems. If it does not, you may have the speakers wired to the wrong ohm load.
SOURCE: will a JL audio 1000/1 amp run a orion HCCA 15
Hello evopower,
The JL 1000/1 will power the Orion HCCA OK.
It is stable only to 1.5 ohms so your best choice would be the 15.4 with dual 4ohm voice coils. In parallel, this would offer a 2ohm impedance. The 15.2 could only be wired for either a 1ohm load (too low) or a 4ohm load (less power).
Hope this helps.
SOURCE: will a Lanzar Vibe 286 4000 watt amp push a power acoustik fubr 12 700 rms 1800 max ....
Yes it should do the job. You will need to wire the sub in series and make sure you have a 4ohm load on the amp. It should be right at around 700 watts RMS @ 12-13 volts.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
