Its your amp. It may be pickin up noise from your car electrical system. Make sure your amp power wire doesn't run along side your RCAs back to the amp. Or you could be pickin up alternator wine, its a problem with the way your wires are run, unless your amp's just producing a bad signal, try turning your amp input gain a little lower, to muck juice into the amp can fuzzy up signals. If you can't find any thing wrong take your amp to an audio shop and they can test it to see if its distorting always, or just cuz of your wiring... Hop this helps you out.
are the speakers in boxes how are u driving them u need an amplifier with either a lo band pass filter or a lo cutoff filter (100hz or less) you will not hear the full sound range only the low end is this what is happening
